I think my tach puked |
Steve Thacker |
Dec 9 2003, 10:45 AM
UMMMPH Yea Baby Yea ! UMMMPH Group: Members Posts: 1,089 Joined: 8-January 03 From: Pickerington, Ohio Member No.: 113 Region Association: Upper MidWest |
Hey all,
I had a strange thing just happened. My tach just quit working "worked perfectly before". I checked to make sure the little wire from the harness is connected to the neg side of the coil and is tight on the blade connector. Unplugging of course stops the engine cold. Is there a way to test to see if a tach is kaput? Thanks!!!! |
seanery |
Dec 9 2003, 11:24 AM
did you check the angle drive at the tranny?
look for lube leaking. |
fiid |
Dec 9 2003, 11:41 AM
unplugging the tach from the coil stops your engine cold? that ain't right, is it? Isn't your points / pertronix/whatever supposed to be connected alongside it??
Fiid. |
fuch toy |
Dec 9 2003, 11:51 AM
Unregistered |
QUOTE(seanery @ Dec 9 2003, 09:24 AM) did you check the angle drive at the tranny? look for lube leaking. That would be the speedo.....nutin to do with the tach. |
seanery |
Dec 9 2003, 03:31 PM
haha....brainfart!
Steve Thacker |
Dec 10 2003, 12:42 PM
I thought or think the little wire on the coil goes to the tach in some sort of fashion or is part of the feed. I can't read electrical diagrams for sh$t. I replaced my points for a crane unit two years ago so I know that isn't coming into play. I'm stumped (IMG:style_emoticons/default/blink.gif)
Lo-Fi Version | Time is now: 15th May 2024 - 01:32 PM |
