Brake pads, any real difference? |
bpu699 |
May 31 2007, 01:17 PM
Newbie Group: Members Posts: 4 Joined: 28-June 06 From: wisconsin Member No.: 6,323 |
I might take my 914 to the track. Brakes are mediocre, and I have read as many threads as possible regarding this issue. Car has new rotors, pads, fluid, caliper rebuild, etc.
Pads, I believe, are "mintex" as replaced by the prior owner. Car stops adequately in everyday traffic, barely adequately on the highway. The brakes do not lock up, ever. Previous owner bled the system multiple times, replaced the lines, etc. So, would porterfield pads make a BIG difference??? Most of the threads mention that the stock system is "great", and can be locked up, assuming you have a properly working system and porterfield pads. Would changing the pads make a world of difference, or is it a waste of time? The porterfield pads will run 300$ or so for all 4 wheels. The BMW front brake upgrade will run the same. Which option is better??? |
Lo-Fi Version | Time is now: 29th May 2024 - 01:53 AM |
