| Jake Raby |
Dec 11 2003, 02:53 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
We are confusing him....
the engines motion is clockwise. Thats why I stated that in my first post, so you would not get confused. The engine fires 1432, clockwise...... basically when cyl#1 is a TDC, number 3 is at overlap and vice versa. valves cannot be adjusted at overlap. |
| trojanhorsepower |
Dec 11 2003, 02:58 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,051 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
OK I went out and spun it again looking at #3
Still facing the fan and turning it CW the Intake valve is remains open as the piston comes up (on any cylender). Surely this would push all the gas/air back out the intake manafold. I have not worked on air cooled motors before what am I missing? Other than the hair that I am pulling out. Grrrrrrrrr (IMG:style_emoticons/default/headbang.gif) -Pete |
| Jake Raby |
Dec 11 2003, 04:58 PM
If that happens turning it CW and all the pushrods are seated correctly- The cam timing is off for sure! are you sure thats the intake valve? They are most inboard on both heads.
sounds like I might ned to ring you up before you tear into it. |
| trojanhorsepower |
Dec 11 2003, 09:11 PM
Sorry guys, I was called away form the computer.
Yes I have checked repeatedly to be sure it is the intake. I will tear down the motor tomorrow. What is the overall stand on the head gasket rings? Lap the cylinders or use the rings. I have the rings in right now, but they are crushed I guess. I called Otto’s to see about ordering some and Steve said not to use them. The concept of no head gasket is very foreign to me, but what ever you all say, will be done. Jake or anybody feel free to call PM or email. PM or email for # that way I will be sure to sit by the right phone. Thanks again for all the help, -Pete |
| Jake Raby |
Dec 11 2003, 09:14 PM
My number is 706 219 4874. I'm here till 3 Am tonite.....
| trojanhorsepower |
Dec 11 2003, 09:18 PM
Running home to get cell phone (free long distance) your phone should ring in 3 min.
-Pete |
| Jake Raby |
Dec 11 2003, 09:50 PM
Try to ring me again...... I heard you beep through but I didn't want to Answer it with a guy from Australia paying for long distance.
| Brad Roberts |
Dec 12 2003, 12:24 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
I still say pushrods.
b |
| Jake Raby |
Dec 12 2003, 09:48 AM
Told him to triple check them.....
| Gint |
Dec 12 2003, 11:00 AM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,108 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
SO?!?! The 914 Soap Opera. Don't keep us in suspense. This is better'n T.V.
Did Pete call Jake? Did Jake diagnose the issue? Will Pete's car run soon? Stay tuned for another thrilling episode of "As the TypeIV crank Turns". P.S. - Beats working in this miserable pit. |
| trojanhorsepower |
Dec 12 2003, 06:04 PM
I have been away for a while, sorry it has taken me so long to post. I am at a dinner party on a friends computer (cable modem is very cool).
I did speak to Jake and he was very helpful. I did not get to work on the motor today, but I should get to it tomorrow. I will take it apart bit by bit and photo as I go, as soon as I have it figured out for sure I will post. I hope to have it back together by Sunday night. What are peoples thoughts on lapping cylinders vs. cylinder head gaskets. I have to go I will check back later tonight. -Pete |
Lo-Fi Version | Time is now: 13th June 2026 - 05:11 AM |
