Half height lift, sitting down |
Randal |
Dec 10 2003, 01:27 AM
On Speed (High Rev Tuners) they had a lift that went up about 4 1/2 feet, or so, and the mechanic just sat on a stool and worked on the underside of the car. The stool had wheels so he could get around pretty easily.
Anyone ever try working under a car sitting down? What's the fatigue factor here? Of course you lose storage, but the real question is whether or not you can do all the same things you could do on a full height lift, without injury? |
DuckRyder |
Dec 10 2003, 05:42 AM
Avatars Mode: OFF because of the recalcitrant few. Group: Benefactors Posts: 767 Joined: 8-January 03 From: Georgia Member No.: 110 |
I used to work on a lot of stuff on the alignment rack which is about that height.
The fatige factor didn't bother me. most of those lifts lift the car on a platform, so pulling a transmission or drive shaft doesn't work too well on conventional cars, but other wise I would think you're good to go. Rotary which makes most of the shop racks in this area has a new line which looks nice: http://www.revolutionlifts.com/default.asp |
URY914 |
Dec 10 2003, 06:44 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,578 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I've always thought those low-height/mid raise lifts would be just the ticket for a home shop. (IMG:style_emoticons/default/wink.gif)
And perfect for a 'teener. Paul |
Eric_Shea |
Dec 10 2003, 12:12 PM
Check out Dales car on two motorcycle lifts...
Steve Thacker |
Dec 10 2003, 12:29 PM
UMMMPH Yea Baby Yea ! UMMMPH Group: Members Posts: 1,089 Joined: 8-January 03 From: Pickerington, Ohio Member No.: 113 Region Association: Upper MidWest |
Now that is the chit! I'm jealous..... (IMG:style_emoticons/default/laugh.gif)
Lo-Fi Version | Time is now: 15th May 2024 - 01:22 PM |
