914-6 heat exchangers |
mark1996 |
Jun 13 2007, 05:58 PM
Newbie Group: Members Posts: 3 Joined: 13-June 07 From: Seattle, Wa Member No.: 7,812 |
For the 914-6, are the oem heat exchangers still available? If not, who sells aftermarket heat exchangers for the 914-6?
PeeGreen 914 |
Jun 13 2007, 06:12 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
You can find OEM ones every now and again, but if you want ones that are in good shape you should go aftermarket. There are a few different companies that make them, but they must be made out of gold as they are over $1500.
dr914@autoatlanta.com |
Jun 13 2007, 06:16 PM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Eric_Shea |
Jun 13 2007, 06:55 PM
I've got a pair that were just refinished. Sandblasted, Expert welded, POR-20 Aluminum finish.
Maltese Falcon |
Jun 13 2007, 07:48 PM
Advanced Member Group: Members Posts: 4,651 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
I'll also have a good set of "Take-offs" avail in July. These also have an extra heat-duct tube on the R-side...which is used for MFI cold start enrichment.
If Eric does'nt sell you his, PM me and perhaps I can hook you up. BTW, all 9146HBs came with tiny exhaust ports...prolly good up thru 2.7 L engines. Unless you really need the heat, you should go with larger dia headers on 3.2/ 3.6/ 3.8 engines. Marty |
jim912928 |
Jun 13 2007, 10:09 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I just placed an order for GHL's with heat...I'll let folks know what I think when I get them (should be about two weeks).
Lo-Fi Version | Time is now: 19th May 2024 - 03:23 AM |
