mark1996
Jun 13 2007, 05:58 PM
For the 914-6, are the oem heat exchangers still available? If not, who sells aftermarket heat exchangers for the 914-6?
PeeGreen 914
Jun 13 2007, 06:12 PM
You can find OEM ones every now and again, but if you want ones that are in good shape you should go aftermarket. There are a few different companies that make them, but they must be made out of gold as they are over $1500.
dr914@autoatlanta.com
Jun 13 2007, 06:16 PM
QUOTE(mark1996 @ Jun 13 2007, 04:58 PM)
readily available but expensive!~
Eric_Shea
Jun 13 2007, 06:55 PM
I've got a pair that were just refinished. Sandblasted, Expert welded, POR-20 Aluminum finish.
Maltese Falcon
Jun 13 2007, 07:48 PM
I'll also have a good set of "Take-offs" avail in July. These also have an extra heat-duct tube on the R-side...which is used for MFI cold start enrichment.
If Eric does'nt sell you his, PM me and perhaps I can hook you up.
BTW, all 9146HBs came with tiny exhaust ports...prolly good up thru 2.7 L engines.
Unless you really need the heat, you should go with larger dia headers on 3.2/ 3.6/ 3.8 engines.
Marty
jim912928
Jun 13 2007, 10:09 PM
I just placed an order for GHL's with heat...I'll let folks know what I think when I get them (should be about two weeks).
