Intermittant Wiper Installation Question, Can I test the Signal Wire ? |
jim_hoyland |
Jun 20 2007, 09:17 PM
Get that VIN ? Group: Members Posts: 9,303 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I have the intermittant wiper harness ready to install and want to test the signal wire first. I untaped the brown wire/blk stripe that was folded back on the loom going toward the wiper motor. Should I get 12 v signal in that wire with the ignition on, and wiper switch in the full-down position ( i removed the tap) ?
I stuck a grounded test light into the connector with the switch on and got NADA Perhaps someone who has does this retro-fit can halp.The wiper switch is either a late model VW or 924. It runs the washer pump in the pull-bak position Thanks, Jim |
Lo-Fi Version | Time is now: 22nd May 2024 - 01:03 AM |
