I figured out what was causing fouled plugs., Anyone want to guess what it was? |
Dr. Roger |
Jun 21 2007, 03:56 AM
I was getting consistent missing and a couple of fouled plugs even after a complete ignition system inspection and plug change.
Pertronix working perfectly. Hot coil working perfectly. New cap, rotor, wires, and plugs. New Edelbrock 750cfm mechanical secondary carb. Settings "close enough". Mallory dizzy. Recurved. (huge difference, I might ad) Fresh rings/heads. quick edit: no air cleaner. I won't let myself live this one down for years.... (IMG:style_emoticons/default/blink.gif) Any guesses as to what was causing the fouled plugs? (IMG:style_emoticons/default/idea.gif) |
So.Cal.914 |
Jun 21 2007, 04:18 AM
(IMG:style_emoticons/default/confused24.gif) Rag in the carb?
Joe Ricard |
Jun 21 2007, 06:46 AM
Loose jet?
Johny Blackstain |
Jun 21 2007, 06:53 AM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
MJHanna |
Jun 21 2007, 06:57 AM
Does this 911 make my butt look big? Group: Members Posts: 805 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
it's a V8 (IMG:style_emoticons/default/poke.gif)
bd1308 |
Jun 21 2007, 09:32 AM
loose nut behind the wheel (IMG:style_emoticons/default/confused24.gif)
AZ914 |
Jun 21 2007, 09:45 AM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
I don't want to guess, just fuchin tell me.
(IMG:style_emoticons/default/smile.gif) |
Allan |
Jun 21 2007, 09:58 AM
Accidentally filled it up with deisel?
messix |
Jun 21 2007, 10:11 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
I was getting consistent missing and a couple of fouled plugs even after a complete ignition system inspection and plug change. Pertronix working perfectly. Hot coil working perfectly. New cap, rotor, wires, and plugs. New Edelbrock 750cfm mechanical secondary carb. Settings "close enough". Mallory dizzy. Recurved. (huge difference, I might ad) Fresh rings/heads. quick edit: no air cleaner. I won't let myself live this one down for years.... (IMG:style_emoticons/default/blink.gif) Any guesses as to what was causing the fouled plugs? (IMG:style_emoticons/default/idea.gif) hydraulic lifters weren't lashed right on the exhaust on those 2 cylinders? |
SLITS |
Jun 21 2007, 10:13 AM
1.) You installed the rings upside down.
2.) Plug gap was to small.a 3.) It's a V8. 4.) Your hand slipped off whist googling the Ladies calendar. |
So.Cal.914 |
Jun 21 2007, 12:31 PM
Is this what you would call a dramatic pause? Give it up already.
Dr. Roger |
Jun 21 2007, 12:33 PM
TROY!
you called it. (IMG:style_emoticons/default/clap56.gif) after static valve adjustment I never went back and readjusted the valves. 3 were tight. (IMG:style_emoticons/default/chair.gif) this one error caused the engine to run hotter, less power (obviously), missing, fouling plugs, some back firing ( (IMG:style_emoticons/default/slap.gif) ), and rough idling. (IMG:style_emoticons/default/dry.gif) i hope someone can benefit from my experience. (IMG:style_emoticons/default/smile.gif) best regards... |
messix |
Jun 21 2007, 12:40 PM
elementary my dear Watson, elementary! (IMG:style_emoticons/default/cool_shades.gif)
Joe Ricard |
Jun 21 2007, 12:51 PM
Ya'll adjust valves?
I ain't adjusted valves in 30,000 miles and only changed oil once in that time. Who am I? |
SLITS |
Jun 21 2007, 12:53 PM
McMark |
Jun 21 2007, 01:24 PM
Ya'll adjust valves? I ain't adjusted valves in 30,000 miles and only changed oil once in that time. Who am I? (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 11:49 PM |
