head temp sensor removal, how?? |
wilchek |
Jun 22 2007, 08:23 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
I am changing the head temp sensor. I pulled the intake runners out so I can get to the head temp sensor. However, I have to use a long 13mm socket to pull the sensor which is like 2 inches in the cooling tin. However the wire on the sensor makes it impossible to attach the ratchet. Any idea if the wire can be removed from the sensor it appears to be heat sealed on the sensor or is it just pushed on. The sensor in the car is tight and I have tried everything to wrench on the socket without the ratchet, no success (lock pliers on socket, screw driver, etc.) . I can cut the line but that is last resort.
Lo-Fi Version | Time is now: 22nd May 2024 - 04:41 PM |
