Unknown mounting bracket., What's it for? |
nola914 |
Jun 23 2007, 10:00 PM
Member Group: Members Posts: 77 Joined: 19-January 06 From: New Orleans, LA Member No.: 5,440 |
I was beginning to clean the engine compartment on my '73 2L while I have the engine out, and I noticed this bracket (inside the rectangle).
It's inside the Left engine mount, welded top and bottom, with a slot from top to bottom. It's original, because you can see the original yellow paint showing through. The PO had something secured there with 2 screw clamps, but nothing was mounted there when I got it. I looked in Haynes and the AA parts diagrams and neither shows a bracket in that location The car has AC, and the compressor would be located just ahead of this area. So... what goes there?? Attached image(s) |
MrKona |
Jun 23 2007, 10:08 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
I was beginning to clean the engine compartment on my '73 2L while I have the engine out, and I noticed this bracket (inside the rectangle). It's inside the Left engine mount, welded top and bottom, with a slot from top to bottom. It's original, because you can see the original yellow paint showing through. The PO had something secured there with 2 screw clamps, but nothing was mounted there when I got it. I looked in Haynes and the AA parts diagrams and neither shows a bracket in that location The car has AC, and the compressor would be located just ahead of this area. So... what goes there?? Perhaps the remains of an old fuel filter mount? Where is your fuel filter presently mounted? |
nola914 |
Jun 23 2007, 10:14 PM
The pump and filter are in the front trunk.
MrKona |
Jun 23 2007, 10:19 PM
Yup, I just took a look under my '74 to confirm. What you have there are the mangled remains of the stock fuel filter mount. Yours has been straightened out. It's supposed to be shaped like a cradle to hold the filter in its original location.
nola914 |
Jun 23 2007, 10:51 PM
Thanks for looking. I'll straighten it out and take off the clamps, so it doesn't look like *rap, and let it rest in piece.
Jun 23 2007, 11:04 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Perhaps the remains of an old fuel filter mount? (IMG:style_emoticons/default/agree.gif) stock fuel filter mount ... (IMG:style_emoticons/default/cool_shades.gif) Andy |
Lo-Fi Version | Time is now: 9th June 2024 - 05:03 PM |
