brake upgrade |
brake upgrade |
por914 |
Jun 25 2007, 01:09 AM
Newbie Group: Members Posts: 4 Joined: 25-June 07 From: Acampo CA Member No.: 7,837 |
Hello I am a new 914 owner and attempting to get the car back on the road. I am having trouble with the rear calipers, seems that the pistons are rusted in the bore and I cant break them loose? So I am thinking of alternative options and just by seeing how small the original calipers are its seems logical to upgrade. What is the best option to upgrade these cars. Will a set of calipers from a 944 T fit on? Or is there a better, easier option? Thanks Heath
PeeGreen 914 |
Jun 25 2007, 01:31 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Hey Heath
I will be interested to see what people will say as well. I do not believe that there are many options out there for threar unless you loose the e-brake. There are a few options if you do that, but I guess the question is how important is the e-brake to you? Jon |
Bleyseng |
Jun 25 2007, 10:17 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
send them to Eric Shea to be rebuilt....way easier than no ebrake. (IMG:style_emoticons/default/laugh.gif)
Eric_Shea |
Jun 25 2007, 10:54 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
We can get the pistons free... if you don't want to spend the loot then call and I'll give you a bunch of tips to help you get it done. Here's a couple simple ones:
1. With the cables off, tap the handbrake arm with a rubber or plastic mallet or softly with a hammer. This will force the inner piston to move breaking the rust bond. BE CAREFUL... look at the side of the arm. There's a stop post there that you don't want to break off. Watch where that arm will travel before you pound away too hard. 2. Turn the inner adjuster with a high speed air wrench or drill (clockwise). This will "usually" get the piston moving. 3. For the outer piston, take the caliper apart and position the outer caliper 1/2 in a vise piston down. Remove the 13mm plastic cover (if there is one.) Remove the retaining clip. Remove the 13mm lock nut. Now, tap the shaft of the adjuster down with the plastic mallet again to break the bond and move the piston out. Now use your 4mm hex to (counterclockwise) bring the adjuster back up. Tap it down agan, further forcing the piston out... rinse, repeat. DO NOT attempt to use the 4mm to turn out this piston if they are stuck as you say. This will only strip and ruin the adjuster. Tap down with a plastic mallet, back adjuster out. Tap down with a plastic mallet, back adjuster out. Tap down with a plastic mallet, back adjuster out until the piston and ajuster fall out. You may want to buy a can of Gunk carb cleaner as well. Recent oil prices have made a gallon of this stuff North of a Jackson but it's worth it. Soak the calipers in there for 3-5 days. Enjoy. (IMG:style_emoticons/default/welcome.png) |
por914 |
Jun 26 2007, 12:13 AM
Thanks so much for the useful information, I will give it a try, if not ,I was just thinking about upgrading them all the way around, huh yeah that would not be good without an e brake. What other option is there as far as upgrades, have heard some use the bmw and or 911 calipers , when these are used does is mean no e brake also? Thanks again you guys are great. (IMG:style_emoticons/default/thumb3d.gif)
Mike D. |
Jun 26 2007, 12:26 AM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
yeah, what eric said...
I just edited my post because I didn't read his all the way...duh.. |
Dr. Roger |
Jun 26 2007, 02:04 AM
Lo-Fi Version | Time is now: 9th June 2024 - 03:32 PM |
