Electrical help, Running light stays on |
watsonrx13 |
Jun 27 2007, 06:08 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
OK, I'm in the process of putting everything back on the teener after the paint job and I've run into a slight problem. When I hooked up the blinkers I have the driver's side running light (not the side markers) stay on when I turn the key to the on position. When I pull the headlight switch once, both running lights come. When I pull the headlight switch a second time, the headlights pop up and come on. So, where do I need to check for this problem? (IMG:style_emoticons/default/huh.gif)
-- Rob |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:42 AM |
