QUOTE(SirAndy @ Jun 27 2007, 08:49 PM)
QUOTE(watsonrx13 @ Jun 27 2007, 04:08 PM)
When I hooked up the blinkers I have the driver's side running light (not the side markers) stay on when I turn the key to the on position.
move your turn-signal lever back to the center position ...
Andy
Nope, each time I tested it, I made certain that the turn-signal was in the neutral position...
I had your same problem develop spontaneously, so I bought a used light switch and began transferring leads 1 by 1 until I realized my '76 switch was different than the used (early?) switch. So I began backtracking 1 by 1. While doing this 2 leads shorted because the shrinkfit insulation on the connectors was in bad shape. Now neither headlite pops up. So, while I can't solve your problem, I can say be careful as it can get alot worse and fast.
It may be a coincidence that your switch went kaput, but possibly you have incidental contact between leads on the switch.
fwiw, I've had 2 cars painted and both came back with mysterious electrical issues. good luck
Yea, that's what I'm worried about....
-- Rob
