OEM Rear Sway Bar Endlinks:, best way to press bushings? Help! |
Johny Blackstain |
Jun 30 2007, 06:44 AM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
So I'm working on making the underside of the LE as pretty as the topside, pull the end links off the rear sway bar & the bushings just disintegrate into yellow crumbs. Yes, I'm changing all my suspension bushings! No big deal, been sitting on new bushings for 3 years & I need to use them now. So how the hell do they get pressed in? I'm having much difficulty in this step & I have a press! I also foresee much difficulty getting them onto the ball mounts on the end of the sway bar. Any thoughts, ideas, recommendations? Thanks
(IMG:style_emoticons/default/cool_shades.gif) Attached image(s) |
914Sixer |
Jun 30 2007, 07:25 AM
I let them get warm in the sun and then put them in a vise and squeeze them in. I lube them up with silicone spray on the metal and the bushing.
Johny Blackstain |
Jun 30 2007, 07:54 AM
I let them get warm in the sun and then put them in a vise and squeeze them in. I lube them up with silicone spray on the metal and the bushing. (IMG:style_emoticons/default/dry.gif) cloudy & rainy today in the valley but thanks I'll try. I was trying cold, w/ a press instead of a vise using lithium grease. They seem to big to fit inside the links & too small inside to fit over the ball. (IMG:style_emoticons/default/cool_shades.gif) |
73Phoenix20 |
Jun 30 2007, 08:01 AM
Member Group: Members Posts: 334 Joined: 15-June 05 From: Michiana Member No.: 4,283 |
Warm all of the components up in a 200 degree oven for a few minutes...
Then (with silicone oven gloves!) carefully press the bushings into the drop links, using a bench vise and a bit of dish soap to lube things up... I like Dawn! To get the bushings back onto the suspension points, I used a large "C" Clamp, with the screw type jaws, and after careful aligning, just kept tightening until it popped on! Have fun! |
Johny Blackstain |
Jun 30 2007, 08:05 AM
Warm all of the components up in a 200 degree oven for a few minutes... Then (with silicone oven gloves!) carefully press the bushings into the drop links, using a bench vise and a bit of dish soap to lube things up... I like Dawn! To get the bushings back onto the suspension points, I used a large "C" Clamp, with the screw type jaws, and after careful aligning, just kept tightening until it popped on! Have fun! Why do I get the impression you've been here & know I'm in for a whole day shot on a stupid sway bar (IMG:style_emoticons/default/biggrin.gif) ? It's going to be a (IMG:style_emoticons/default/headbang.gif) right? (IMG:style_emoticons/default/cool_shades.gif) |
73Phoenix20 |
Jun 30 2007, 08:18 AM
The toughest part is trying to keep the darned bushing cups aligned onto the "Balls" while you get the Clamp into position...
I tried every Clamp I had before I finally got one to fit and work... There is probably a much better Porsche approved way to do this, but I don't know it! You will get to know your Hardware Store personnel very well by the time you find the correct Clamp! |
Johny Blackstain |
Jun 30 2007, 09:51 AM
It's 10:49 AM & we're done. I'd like to thank the "World" for this momenteous occasion, that of proving the old cliche': "the right tool for the right job." I used a padded vise, teflon instead of silicone, a big screwdriver & I simmered the bushings in well water on the stove. Thank you Teeners! (IMG:style_emoticons/default/biggrin.gif)
(IMG:style_emoticons/default/cool_shades.gif) (now comes the hard part- getting them over those damned ball ends! (IMG:style_emoticons/default/chair.gif) ) Attached image(s) |
Jun 30 2007, 10:21 AM
I had used a vise to push the bushings in, and a screwdriver to poke at the edges to get them started.
At one point, I had picked up one of those "squeeze the handle to tighten" clamps, and that worked pretty well for installing the link onto the trailing arm. I could use two hands to keep the clamp in position, and at the same time tighten it up until it popped onto the ball. --DD |
73Phoenix20 |
Jun 30 2007, 11:04 AM
I now wonder if a large jawed "Welding" Visegrip type tool could be used to pop the Bushings over the Balls???
Be sure to lube your "Balls" before you try an "Pop" them!!! (IMG:style_emoticons/default/laugh.gif) |
Cap'n Krusty |
Jun 30 2007, 11:06 AM
BF Channel-Locks work just fine for installing the sockets on the balls. The Cap'n
Johny Blackstain |
Jun 30 2007, 01:18 PM
BF Channel-Locks work just fine for installing the sockets on the balls. The Cap'n (IMG:style_emoticons/default/agree.gif) Bingo! The Cap'n called it & it's cake. Big old channel locks pop them suckers right on. Used teflon spray first inside the bushings & then painted w/ lithium grease. Overkill... so no probs (IMG:style_emoticons/default/biggrin.gif) . (IMG:style_emoticons/default/cool_shades.gif) BTW- no afiliation but there's one of these on eBay for $550.00- http://cgi.ebay.com/ebaymotors/Porsche-914...1QQcmdZViewItem This post has been edited by Johny Blackstain: Jun 30 2007, 05:12 PM Attached image(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 02:31 AM |
