Involuntary heat-cycling, race tire in trunk |
mskala |
Jul 1 2007, 10:17 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Hey, like some of us, my spare is original (tubed 165) and doesn't hold air anyway, so I leave it at home and put on of my V710's in the rear trunk in case I need a spare.
I drive my car to work in the summer often, and that tire gets pretty warm in the trunk while out in the sun. It even smells like rubber when I open. So, am I accidentally putting heat cycles on this tire and will it harden earlier than otherwise? Seeking wisdom of the tire gods. (IMG:style_emoticons/default/pray.gif) |
Borderline |
Jul 2 2007, 09:04 AM
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
Not to mention the heat from the engine and exhaust. I wouldn't put any tiars that I cared about back there. There was a thread a while back about the proper care of tires. Storing them in a cool dry place in plastic bags. (IMG:style_emoticons/default/smile.gif)
Joe Ricard |
Jul 2 2007, 09:35 AM
If you have SSI's and a Burschh or some sort of Exhaust you will certainly get the trunk over 140-150 degrees
Sitting in the trunk in the sun is also going to be pulling the "good" out of the rubber. Just buy a new tire for a spare. 35 bucks for a cheapy tire that hopefully you will never use. My rear trunk is not as hot as it used to be now that I have a Tangerine and I only can carry one 11" slick in each trunk and 2 on the passenger seat. |
mskala |
Jul 2 2007, 11:10 AM
Thanks, will remedy this before the tire gets old. (new this season).
I can put it in the front trunk or I have to find a wheel+tire. Dang 924S extra junk wheels won't fit, need longer studs+spacers |
Lo-Fi Version | Time is now: 18th May 2024 - 03:17 PM |
