biosurfer1 |
Teener fo Life! ![]() ![]() ![]() ![]() Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California ![]() |
i saw a kit on ebay and got to wondering how high on the "things to do to the 914" list? how much does it help? i have seen a few posts on the bird saying the kits on ebay arn't very good, any comments?
ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
Did it, made a big difference. Get the German kit, not the cheaper one. If your ball joints are shot, you probably wont notice that much difference. Do it all at once (tie rods, ball joints, wheel bearings...)
biosurfer1 |
any links to that german kit?
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Had a bad tie rod end. Figured it was cheaper to do a turbo kit than piece by piece replace with stock. Steering was more accurate but then nothing was loose anymore.
ChrisReale |
Most suppliers sell the German one, a few have bought the cheep one on ebay. Just get the proper part numbers, and compare them to the one you plan on buying.
boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
Recommend the Turbo tie rod kit. I have done this to three of my cars and it made a huge change for the better. One more thing. Have a four wheel alignment done at the same time.
You will be very satisfied. CCLINSLOTCARHEAVEN |
bernbomb914 |
one of the oldest Farts on this board ![]() ![]() ![]() Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 ![]() ![]() |
Its hard to compare because everything is worn out before but when you change the ball joints, wheel bearings, bushings, struts, and install tubro tie rod ends there is a great deal of dfferance in how the car turns in. Bernie
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
FYI:
It also gives you more road feedback thru the steering wheel (you will feel more bumps in the pavement). I do it to all of the cars we build... but it is not a "must have" on my list. I evaluate each customer and see if they really need them or not. b |
StratPlayer |
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,335 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains ![]() ![]() ![]() |
Installed the kit last winter while I was having the BMW upgrade done.
biosurfer1 |
and?
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
i did the swap. but i also did ball joints AND put koni reds AND triad upper strut mounts AND a 4way alignment. with doing such a wholesale change it's hard to pin point which was the greater improvement item. it steers like a completely different car.
kevin |
ss6 |
fun city... ![]() ![]() Group: Members Posts: 261 Joined: 2-February 03 From: Western Connecticut Member No.: 221 ![]() |
Adding the turbo tie rods produced a noticeable improvement in steering "crispness" even after having upgraded the front end with 911 running gear and new bearings / ball joints. Highly recommended. Like going from a shotgun to a rifle.
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,096 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
The last set I did was also a wholsale change. I powdercoated ALL of the suspension and installed Bils front and rear, new poly bushings front and rear, turbo tie rods. Couldn't even recognize the car if you were blindfolded behind the wheel. (IMG:style_emoticons/default/rolleyes.gif)
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
I like the turbo tie rods for my AX car but I'd think 2x about it on my stock 914 (the money vs the benefit). You may want to upgrade your entire front end, or not.... what are you going after???
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
im doing mine in a week or so. ill let you know.
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Brad is setting me up with the entire set up for my car.. Mine are shot right now, just like the entire rest of the suspension... After I get Konis on 4 corners and some Brad tricks I'll be able to use all my 2316cc power.
rhodyguy |
just to buy ends,castelated nuts, and boots is $82. you still have to content with the old u -joints and worn out related crap. if you should do the ball joints consider buying a new ball joint pin or 2 when you order. mine came out REAL hard. "good morning, pelican parts..."
kevin |
Lo-Fi Version | Time is now: 8th July 2025 - 10:49 AM |
