biosurfer1
Dec 13 2003, 08:54 PM
i saw a kit on ebay and got to wondering how high on the "things to do to the 914" list? how much does it help? i have seen a few posts on the bird saying the kits on ebay arn't very good, any comments?
ChrisReale
Dec 13 2003, 08:57 PM
Did it, made a big difference. Get the German kit, not the cheaper one. If your ball joints are shot, you probably wont notice that much difference. Do it all at once (tie rods, ball joints, wheel bearings...)
biosurfer1
Dec 13 2003, 09:00 PM
any links to that german kit?
Joe Ricard
Dec 13 2003, 09:03 PM
Had a bad tie rod end. Figured it was cheaper to do a turbo kit than piece by piece replace with stock. Steering was more accurate but then nothing was loose anymore.
ChrisReale
Dec 13 2003, 09:06 PM
Most suppliers sell the German one, a few have bought the cheep one on ebay. Just get the proper part numbers, and compare them to the one you plan on buying.
boxstr
Dec 13 2003, 10:58 PM
Recommend the Turbo tie rod kit. I have done this to three of my cars and it made a huge change for the better. One more thing. Have a four wheel alignment done at the same time.
You will be very satisfied.
CCLINSLOTCARHEAVEN
bernbomb914
Dec 13 2003, 11:07 PM
Its hard to compare because everything is worn out before but when you change the ball joints, wheel bearings, bushings, struts, and install tubro tie rod ends there is a great deal of dfferance in how the car turns in. Bernie
Brad Roberts
Dec 13 2003, 11:35 PM
FYI:
It also gives you more road feedback thru the steering wheel (you will feel more bumps in the pavement).
I do it to all of the cars we build... but it is not a "must have" on my list. I evaluate each customer and see if they really need them or not.
b
StratPlayer
Dec 13 2003, 11:51 PM
Installed the kit last winter while I was having the BMW upgrade done.
biosurfer1
Dec 14 2003, 02:37 AM
and?
rhodyguy
Dec 14 2003, 09:02 AM
i did the swap. but i also did ball joints AND put koni reds AND triad upper strut mounts AND a 4way alignment. with doing such a wholesale change it's hard to pin point which was the greater improvement item. it steers like a completely different car.
kevin
ss6
Dec 14 2003, 09:21 AM
Adding the turbo tie rods produced a noticeable improvement in steering "crispness" even after having upgraded the front end with 911 running gear and new bearings / ball joints. Highly recommended. Like going from a shotgun to a rifle.
Gint
Dec 14 2003, 12:32 PM
The last set I did was also a wholsale change. I powdercoated ALL of the suspension and installed Bils front and rear, new poly bushings front and rear, turbo tie rods. Couldn't even recognize the car if you were blindfolded behind the wheel.
EdwardBlume
Dec 14 2003, 05:22 PM
I like the turbo tie rods for my AX car but I'd think 2x about it on my stock 914 (the money vs the benefit). You may want to upgrade your entire front end, or not.... what are you going after???
Aaron Cox
Dec 14 2003, 05:28 PM
im doing mine in a week or so. ill let you know.
Jake Raby
Dec 14 2003, 07:37 PM
Brad is setting me up with the entire set up for my car.. Mine are shot right now, just like the entire rest of the suspension... After I get Konis on 4 corners and some Brad tricks I'll be able to use all my 2316cc power.
rhodyguy
Dec 14 2003, 09:02 PM
just to buy ends,castelated nuts, and boots is $82. you still have to content with the old u -joints and worn out related crap. if you should do the ball joints consider buying a new ball joint pin or 2 when you order. mine came out REAL hard. "good morning, pelican parts..."
kevin
