> Pulled the tank Vol V, Total Rust Bucket
BahnBrenner914
post Jul 2 2007, 10:06 PM
The girl is gone and all I have now is a beat-up teener
From: Gig Harbor and University Place, WA :: School in Angola, IN :: girlfriend in Sarasota, FL
Took out the gas tank and it indeed is full of (IMG:style_emoticons/default/stromberg.gif) . I'll let the pics tell the rest:
4 Pages V  1 2 3 > »
Replies(1 - 19)
BahnBrenner914
post Jul 2 2007, 10:07 PM
The tank:
BahnBrenner914
post Jul 2 2007, 10:08 PM
The gas from the bottom of the tank that didnt syphon out: (IMG:style_emoticons/default/barf.gif)
BahnBrenner914
post Jul 2 2007, 10:09 PM
and inside the tank (if you have small children in the room, you'll want them to leave): (IMG:style_emoticons/default/barf.gif) (IMG:style_emoticons/default/icon8.gif) (IMG:style_emoticons/default/stromberg.gif)
McMark
post Jul 2 2007, 10:31 PM
914 Freak!
Yup, not surprised given the issues you've been having. And you've even got HOLES!
Time to go tank hunting.
BahnBrenner914
post Jul 2 2007, 10:38 PM
Thats a reflection, not a hole. But it is chock full of rust. I rinsed it a couple times with alcohol, but theres still a good amount of gunk in there.
McMark
post Jul 2 2007, 10:40 PM
914 Freak!
Get a couple gallons of Muriatic Acid and CAREFULLY wash out the inside. Dilute the acid with water and use appropriate safety gear. We don't want you messing up yer face and losing your hot girlfriend. (IMG:style_emoticons/default/laugh.gif)
BahnBrenner914
post Jul 2 2007, 10:56 PM
QUOTE(McMark @ Jul 2 2007, 09:40 PM) *
Check (IMG:style_emoticons/default/bravo.gif)
BahnBrenner914
post Jul 2 2007, 11:08 PM
Also, my dad was talking about putting some ball bearings in there (IMG:style_emoticons/default/w00t1.gif) to break up the rust, is this kosher?
PeeGreen 914
post Jul 2 2007, 11:12 PM
"Are you out of it boys? Everything is ball bearings these days." (IMG:style_emoticons/default/chairfall.gif)
I don't know what the ball bearings would do, but I have heard of a sealer to put in the tank that will coat everything to make it like new.
BahnBrenner914
post Jul 3 2007, 12:37 AM
The ball bearings (IMG:style_emoticons/default/w00t1.gif) (IMG:style_emoticons/default/w00t1.gif) (IMG:style_emoticons/default/w00t1.gif) would break off the rust that wont wash off with alcohol/acid/water so it's all clean when seal it, cause there's no point in sealing up rust.
Danny_Ocean
post Jul 3 2007, 12:41 AM
QUOTE(BahnBrenner914 @ Jul 3 2007, 02:37 AM) *
The ball bearing trick may have worked on Dad's keen '59 Nash Rambler, but there are too many uneven surfaces/hiding places in our tanks for this method to remove all rust.
Have it professionally hot-tanked and pressure tested. Then seal with POR-15 tank sealer.
Do it right, do it once.
GWN7
post Jul 3 2007, 12:42 AM
King of Road Trips
The other option is take it to a rad shop and have them boil it clean.
Try the acid and ball bearings first and see how clean it comes.
Gint
post Jul 3 2007, 12:54 AM
Mike Ginter
Here we go again...
Take it to a radiator shop and spend $35 to have it boiled, or otherwise tanked with a suitable alternative. If you have a shop with an ultrasonic tank you won' t believe how good it looks when it comes back. They know their business and you won't torch your digits with acid.
rhodyguy
post Jul 3 2007, 01:54 AM
nice tanks will be fetching good money before you know it.
k
PeeGreen 914
post Jul 3 2007, 02:02 AM
I hit myself everytime I think that I sold a very clean tank to Denny Acre for 50 bucks last year. I should have held on to it. All is well when helping a teener out though.
1bad914
post Jul 3 2007, 05:51 AM
Take a short length ( 1 foot) of link chain and put it in the tank, then dance around your garage with the tank and chain. First off rinse the tank out, let it dry, then do the chain trick, do this for a awhile, dance and shake, beverage of choice, dance and shake, beverage of choice...you get it! Then rinse it out well and let it dry, then seal it with por-15 tank sealer. Mine is going on 5 years now and is working fine!
type11969
post Jul 3 2007, 07:52 AM
Did that with my Beetle tank 10 years ago and it is still spotless inside. I used the Eastwood kit though.
-Chris
Phoenix914
post Jul 3 2007, 08:23 AM
I also recommend using the chain method to clean up that gunk. Put it in the tank with some hot water and Castrol Super Clean or your favorite degreaser. Then use the POR-15 tank sealer. Better yet, buy the whole tank restoration kit - it comes with everything you need.
edit:
By the way, I just wanted to note that your fuel tank compartment looks pretty darn clean. Mine did not look that good...
IanStott
post Jul 3 2007, 08:36 AM
I sent mine out to get professionally done and am very happy with the result, much better job than I could have done and no muss no fuss in my backyard! Tanks are very rare where I live and was mentioned above are only going to get harder to obtain, save yours if you can, you will be glad you did.
Ian Stott
Moncton
Canada
4 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 27th June 2026 - 02:10 AM
