TRANS OIL |
TRANS OIL |
kojo2001 |
Jul 5 2007, 01:12 PM
Member Group: Members Posts: 88 Joined: 22-June 07 From: california Member No.: 7,832 |
Hi
I just got a 73' and want to have the tranny oil changed what type are you suppose to use?? |
Cap'n Krusty |
Jul 5 2007, 01:25 PM
Hi I just got a 73' and want to have the tranny oil changed what type are you suppose to use?? Why? Unless you suspect a problem, or you want to look at the drain plug magnet for particles, there's no need to change the gear oil. It doesn't wear out. You MUST use an oil that meets GL5 Specifications, preferably an 80w90 or 80/90/140. DO NOT USE ANY OTHER OIL. Not GL4, not anything with a moly additive, not limited slip additive, not any oil which it covers a range of GL specs. There are synthetics out there, and other oils that meet the specs, but you have to be careful what you buy. If the parts counterman tells you otherwise, treat him like the dummy he is, and go elsewhere. Most VW shops carry GL4, BTW, which you shouldn't use. Works fine in their trannies, but not yours. The Cap'n |
kojo2001 |
Jul 5 2007, 01:33 PM
Hi I just got a 73' and want to have the tranny oil changed what type are you suppose to use?? Why? Unless you suspect a problem, or you want to look at the drain plug magnet for particles, there's no need to change the gear oil. It doesn't wear out. You MUST use an oil that meets GL5 Specifications, preferably an 80w90 or 80/90/140. DO NOT USE ANY OTHER OIL. Not GL4, not anything with a moly additive, not limited slip additive, not any oil which it covers a range of GL specs. There are synthetics out there, and other oils that meet the specs, but you have to be careful what you buy. If the parts counterman tells you otherwise, treat him like the dummy he is, and go elsewhere. Most VW shops carry GL4, BTW, which you shouldn't use. Works fine in their trannies, but not yours. The Cap'n Thanks tranny seems pretty good but i notice first sometimes grinds a little a wanted to see how to smooth out a little?? Also do you recomend useing those gas additives to help cleen carbs an reduce carbon build up? car was sitting for a while?? Any recomendations I am new to all this? Thanks |
Cap'n Krusty |
Jul 5 2007, 01:48 PM
Hi I just got a 73' and want to have the tranny oil changed what type are you suppose to use?? Why? Unless you suspect a problem, or you want to look at the drain plug magnet for particles, there's no need to change the gear oil. It doesn't wear out. You MUST use an oil that meets GL5 Specifications, preferably an 80w90 or 80/90/140. DO NOT USE ANY OTHER OIL. Not GL4, not anything with a moly additive, not limited slip additive, not any oil which it covers a range of GL specs. There are synthetics out there, and other oils that meet the specs, but you have to be careful what you buy. If the parts counterman tells you otherwise, treat him like the dummy he is, and go elsewhere. Most VW shops carry GL4, BTW, which you shouldn't use. Works fine in their trannies, but not yours. The Cap'n Thanks tranny seems pretty good but i notice first sometimes grinds a little a wanted to see how to smooth out a little?? Also do you recomend useing those gas additives to help cleen carbs an reduce carbon build up? car was sitting for a while?? Any recomendations I am new to all this? Thanks Use something like Techron as a fuel system cleaner. The one you buy at Chevron stations is stronger than what they sell at parts stores. It's doubtful changing the gear oil will improve your shifting, although there are people who say Swepco does. Grinding is generally either a wear problem, or a clutch problem. In either case, fresh gear oil won't make a difference. The Cap'n |
kojo2001 |
Jul 5 2007, 01:51 PM
Hi I just got a 73' and want to have the tranny oil changed what type are you suppose to use?? Why? Unless you suspect a problem, or you want to look at the drain plug magnet for particles, there's no need to change the gear oil. It doesn't wear out. You MUST use an oil that meets GL5 Specifications, preferably an 80w90 or 80/90/140. DO NOT USE ANY OTHER OIL. Not GL4, not anything with a moly additive, not limited slip additive, not any oil which it covers a range of GL specs. There are synthetics out there, and other oils that meet the specs, but you have to be careful what you buy. If the parts counterman tells you otherwise, treat him like the dummy he is, and go elsewhere. Most VW shops carry GL4, BTW, which you shouldn't use. Works fine in their trannies, but not yours. The Cap'n Thanks tranny seems pretty good but i notice first sometimes grinds a little a wanted to see how to smooth out a little?? Also do you recomend useing those gas additives to help cleen carbs an reduce carbon build up? car was sitting for a while?? Any recomendations I am new to all this? Thanks Use something like Techron as a fuel system cleaner. The one you buy at Chevron stations is stronger than what they sell at parts stores. It's doubtful changing the gear oil will improve your shifting, although there are people who say Swepco does. Grinding is generally either a wear problem, or a clutch problem. In either case, fresh gear oil won't make a difference. The Cap'n thanks |
Lo-Fi Version | Time is now: 18th May 2024 - 04:56 AM |
