Installing distributor pinion gear, at right angle |
thomasotten |
Jul 6 2007, 08:35 AM
Senior Member Group: Members Posts: 1,545 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
So, I was thinking about this on the way to work. When rebuilding an engine, how do you make sure that the distributor pinion gear is going in at the right angle? I watched Jake's video, where he set the rotor to line up with the notch on the distributor housing, then stabs the distributor and the pinion gear at the same time. But, then, doesn't that assume that your distributor was timed and not moved when you took it off? Mine has the fastening clamp removed already. Will it ever really matter?
Lo-Fi Version | Time is now: 19th May 2024 - 09:02 AM |
