what flywheel for 3.0 six conversion? |
rfuerst911sc |
Jul 11 2007, 04:41 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
It is my understanding that my 911 3.0 engine I am going to use in the /6 conversion that I need a different/special flywheel to be used with the 901 tranny? So if that is accurate what flywheel do I have to purchase? Is it a OEM or aftermarket? Any suggestions on where to buy and a part number? And what about pressure plate and clutch disc? For those of you that have gone this route any problems I should be aware of? Thanks (IMG:style_emoticons/default/beerchug.gif)
Van914 |
Jul 11 2007, 05:49 AM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
I am in process of this conversion also. I bought from Patrick Motorsports their Starter Ring and Clutch setup. It uses the stock 911 flywheel. Here is their Web Site http://www.patrickmotorsports.com/
Good luck with yours. van914 |
rfuerst911sc |
Jul 11 2007, 10:54 AM
I will contact them. Thanks
IronHillRestorations |
Jul 11 2007, 12:22 PM
You can get the same thing from Kennedy. I'll bet they make the parts Patrick is selling. You can get one that uses the 3.0 flywheel.
rfuerst911sc |
Jul 11 2007, 01:01 PM
Who or what is Kennedy? Contact info? Thanks
rfuerst911sc |
Jul 11 2007, 05:21 PM
I found the Kennedy website. Looks good. Thanks
Krieger |
Jul 11 2007, 07:28 PM
Advanced Member Group: Members Posts: 4,710 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
About two years ago I asked Jim at Patrick why I should by his instead of Kennedy's for $100 less. He had no response. The kennedy piece *may* be a 914 flywheel with the clutch face surface removed, so it is just a 1" ring with teeth for the starter. It bolts right up to the 3.0 flywheel very nicely.
Lo-Fi Version | Time is now: 16th May 2024 - 12:37 AM |
