rfuerst911sc
Jul 11 2007, 04:41 AM
It is my understanding that my 911 3.0 engine I am going to use in the /6 conversion that I need a different/special flywheel to be used with the 901 tranny? So if that is accurate what flywheel do I have to purchase? Is it a OEM or aftermarket? Any suggestions on where to buy and a part number? And what about pressure plate and clutch disc? For those of you that have gone this route any problems I should be aware of? Thanks
Van914
Jul 11 2007, 05:49 AM
I am in process of this conversion also. I bought from Patrick Motorsports their Starter Ring and Clutch setup. It uses the stock 911 flywheel. Here is their Web Site
http://www.patrickmotorsports.com/Good luck with yours.
van914
rfuerst911sc
Jul 11 2007, 10:54 AM
I will contact them. Thanks
IronHillRestorations
Jul 11 2007, 12:22 PM
You can get the same thing from Kennedy. I'll bet they make the parts Patrick is selling. You can get one that uses the 3.0 flywheel.
rfuerst911sc
Jul 11 2007, 01:01 PM
Who or what is Kennedy? Contact info? Thanks
rfuerst911sc
Jul 11 2007, 05:21 PM
I found the Kennedy website. Looks good. Thanks
Krieger
Jul 11 2007, 07:28 PM
About two years ago I asked Jim at Patrick why I should by his instead of Kennedy's for $100 less. He had no response. The kennedy piece *may* be a 914 flywheel with the clutch face surface removed, so it is just a 1" ring with teeth for the starter. It bolts right up to the 3.0 flywheel very nicely.
