Stop Light Switch, Is it a VW part? |
andys |
Jul 11 2007, 11:17 PM
Is the stop light switch on the pedal cluster a VW part, or a Porsche specific part?
Thanks, Andys |
Dr Evil |
Jul 11 2007, 11:55 PM
Not sure, but if you need one I am sure folks have them lying around. I might even have one.
davep |
Jul 12 2007, 11:37 AM
I'm pretty sure it is a 914-only part, or at least a Porsche part.
Like most guys I have several in my stash. |
Cap'n Krusty |
Jul 12 2007, 11:39 AM
It is NOT a VW part. VW used pressure switches. BTW, many perceived brake light switch problems are simply cases of improper installation, and easily corrected. The Cap'n
Eric_Shea |
Jul 12 2007, 12:07 PM
I've got some if you need one... pay the shipping. El Capitano is correct. The switch arm should be on the outside of the washer (closest to you) so when you depress the pedal, the switch follows.
andys |
Jul 12 2007, 01:03 PM
The switch was originally installed correctly, but one of the ears with the threaded insert is completely cracked. Still functions but prone to failure.
Interesting; if you go to your FLAPS, they pull a pressure switch. Eric, you have a PM Thanks, Andys |
MartyYeoman |
Jul 12 2007, 07:30 PM
Senior Member Group: Members Posts: 1,518 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Funny you should ask. I just replaced mine last week.
I ran mine with a broken tab for about five years before it gave up the ghost. Watch your volt meter. If it doen't jump when you push the pedal, it's time for the fix. By the way, I need another switch for my garage shelf now. Any offers? |
Allan |
Jul 12 2007, 07:44 PM
That is just what the Cap'n ordered.
I was in the same boat a year ago and found that the pivot arm had just simply "Jumped the track" sort of. Make sure that the lever is not bent and in FRONT of the pedal. Mine was simple, I hope your's is too..... |
Cap'n Krusty |
Jul 12 2007, 08:05 PM
The switch was originally installed correctly, but one of the ears with the threaded insert is completely cracked. Still functions but prone to failure. Interesting; if you go to your FLAPS, they pull a pressure switch. Eric, you have a PM Thanks, Andys Whatever were you doing in a FLAPS? The Cap'n |
Lo-Fi Version | Time is now: 16th May 2024 - 06:10 AM |
