shards found in sump, should i be as annoyed as i am? |
lotus_65 |
Jul 12 2007, 08:18 AM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
i check the sump every other time i change oil, so about 5000 miles ago there was nothing, now this.
it's been 9100 miles of admittedly pretty hard street driving on my 2056. i'm still struggling with jetting issues, oil burning and seeping, etc. these shards are steel, and almost look like threads. but the one is bifurcated, so i don't think they are. anyone have a guess where they may have come from and if I should be planning another teardown... (IMG:style_emoticons/default/mad.gif) thanks paul Attached thumbnail(s) |
lotus_65 |
Jul 12 2007, 08:19 AM
more
IronHillRestorations |
Jul 12 2007, 08:20 AM
Maybe the drain plug hole?
lotus_65 |
Jul 12 2007, 08:23 AM
god i hope not, i'm really strict with the torque wrench to spec.
Aaron Cox |
Jul 12 2007, 08:48 AM
those look like helicoil chunks.....
Joe Ricard |
Jul 12 2007, 09:10 AM
Question about your process for changing oil.
When you change the filter do you remove it and then turn it upside down in the drain pan? Next time don't do that. Coulda been in the filter innards. I agree it looks like threads. might be thread cutting from the filter. Do you feel better now? Or you got a really big effin problem. |
lotus_65 |
Jul 12 2007, 03:33 PM
i worked from the bottom up, so i removed the sump and found the shards way before removing the filter.
this weekend i'm going to drop the oil again and look for stripped threads on the sump pickup and the drain plug. i'm betting on the big effen problem knowing my luck with this rebuild... thanks, and i'll post results when i get 'em. |
McMark |
Jul 12 2007, 04:50 PM
Test #1: Are they magnetically attracted? Good luck... (IMG:style_emoticons/default/unsure.gif)
john rogers |
Jul 12 2007, 05:12 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I would pull the valve covers to see if anything has broken on the top end.
lotus_65 |
Jul 13 2007, 05:17 AM
yes, they are magnetic. that was one of the first things i checked.
i owe the car a valve adjustment, so i'll inspect there too. |
Lo-Fi Version | Time is now: 21st May 2024 - 01:48 AM |
