Removing Spray paint from under the front bumper, Please Help! |
jonferns |
Jul 18 2007, 01:58 PM
Hey, I took off the valance yesterday, and noticed some black paint drips and that under the front bumper its painted black...is it supposed to be like this? Thanks
(IMG:http://i133.photobucket.com/albums/q44/sendjonathanmail/IMG_1787.jpg) |
Ferg |
Jul 18 2007, 02:06 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Nope.
How far under does the black go? They may have repainted the bumper on the car, and the fog grill opening was not taped off... Ferg |
1970 Neun vierzehn |
Jul 18 2007, 02:11 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
Jon,
Here's a pic of the front of a '70/4 w/o valence and bumper. That area would be painted body color, as I would imagine later MYs would be. Attached image(s) |
jonferns |
Jul 18 2007, 02:18 PM
I just went out to the garage and checked, Ferg was right, it is only painted in the fog light opening...the PO probably repainted the bumper at one point, and didnt mask....the rest is yellow
G e o r g e |
Jul 18 2007, 02:41 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
jonferns |
Jul 18 2007, 02:51 PM
Some parts of the car will have to be repainted in the near future anyway. I can just have it painted over
Ferg |
Jul 18 2007, 02:59 PM
some parts of the car will have to be repainted in the near future anyway...I will paint over the black, and make it yellow again...And use wurth paint for the bumpers? Before you do that, try and remove the black with some thinner of sorts, (I don't know what to recommend...) Ferg. |
Johny Blackstain |
Jul 18 2007, 03:07 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
some parts of the car will have to be repainted in the near future anyway...I will paint over the black, and make it yellow again...And use wurth paint for the bumpers? Before you do that, try and remove the black with some thinner of sorts, (I don't know what to recommend...) Ferg. Try some non-chlorinated brake cleaner to take paint off & not hurt the paint underneath. Also try a lot of elbow grease & rubbing compound. Test these in non conspicuous spots first before all the yellow melts off & you say I owe you a paint job (IMG:style_emoticons/default/biggrin.gif) . |
jonferns |
Jul 18 2007, 03:14 PM
QUOTE Try some non-chlorinated brake cleaner to take paint off & not hurt the paint underneath. Also try a lot of elbow grease & rubbing compound. Test these in non conspicuous spots first before all the yellow melts off & you say I owe you a paint job (IMG:style_emoticons/default/biggrin.gif) . sounds good man...ill see if it works tonight, when I go buy some...if not, ill be back |
jonferns |
Jul 18 2007, 07:57 PM
OK, so I removed the bumper, and spent over an hour and a half rubbing the spray painted area with paint thinner...After letting it sit on there for a few minutes, the light areas came off (but still not easily)..overall, in 1 hour, I completed a 3" x 3" area...Is there anything else I can use (as far as chemicals go) to remove this crap?
I didnt have a chance to head down to the FLAPS, but will tomorrow to get the brake cleaner doh! I forgot to try the rubbing compound, I have some 3M stuff, let me go try that thanks alot everyone |
Pat Garvey |
Jul 18 2007, 08:39 PM
OK, so I removed the bumper, and spent over an hour and a half rubbing the spray painted area with paint thinner...After letting it sit on there for a few minutes, the light areas came off (but still not easily)..overall, in 1 hour, I completed a 3" x 3" area...Is there anything else I can use (as far as chemicals go) to remove this crap? I didnt have a chance to head down to the FLAPS, but will tomorrow to get the brake cleaner (non-chlorinated)... doh! I forgot to try the rubbing compound, I have some 3M stuff...ill see if that works...so, please feel free to suggest something...I need help! thanks alot everyone -JON Here's what I've had success with - on other cars. First - leave the paint run streaks until last. They may not even show after the bumper is back in place. I have a suggestion for those, but it could be severe, so leave them alone for now. Concentrate on seeing yellow behind the grills. Don't use any harsh chemicals! No brake cleaner & especially no thinner!!!!!! Expect to spend some time & use a quality, soft rubbing compound. Not the paste in a can either - too harsh. I have had good luck with (yep, it's pedestrian) Turtle Wax liquid rubbing compound. Use it sparingly, with light rubbing in a linear fashion (no roundy round stuff). It'll take it off. May take several attempts, but it WILL come off. Just try not to go deeply into the yellow/original paint. If the runs still show, PM me for some REALLY CAUTIOUS attempts at removing it, because the runs are thick & will take more extreme measures (probably). Pat |
Johny Blackstain |
Jul 18 2007, 08:45 PM
OK, so I removed the bumper, and spent over an hour and a half rubbing the spray painted area with paint thinner...After letting it sit on there for a few minutes, the light areas came off (but still not easily)..overall, in 1 hour, I completed a 3" x 3" area...Is there anything else I can use (as far as chemicals go) to remove this crap? I didnt have a chance to head down to the FLAPS, but will tomorrow to get the brake cleaner (non-chlorinated)... doh! I forgot to try the rubbing compound, I have some 3M stuff...ill see if that works...so, please feel free to suggest something...I need help! thanks alot everyone -JON Jon- there's a multitude of chemicals you can use but you're trying to protect the yellow underneath no? The non-chlorinated brake cleaner seems like it will be the best but be careful- test first! It's what I've been using to take the undercoating off of my suspension components & dirt/grease off of my painted hinges. Rubbing compund will also take a lot of effort & you can go through the yellow w/ that as well. Be careful & take your time. As to the brand I use it's good old fashioned turtle wax rubbing compound. Been around now for 900 years & it works. |
jonferns |
Jul 19 2007, 07:48 AM
I currently have this stuff in my garage, think its good?
-JON |
Johny Blackstain |
Jul 19 2007, 08:08 AM
I currently have this stuff in my garage, think its good? -JON I don't see why not? I've never used it but I know 3M makes good stuff. If it's really runny, not very paste like, it's probably meant for a machine & not hand use. That does not mean you can't use your hand & it should work. It will take effort. Never use the paste & a machine- always by hand w/ paste. |
jonferns |
Jul 19 2007, 09:45 AM
its a little liquidy, but not too too runny....I will give it a shot
Pat Garvey |
Jul 19 2007, 09:14 PM
its a little liquidy, but not too too runny....I will give it a shot Just take it slowly! If you get down to pure yellow - stop. Work in small areas, until it's all yellow. Use light strokes! When it looks like you've uncovered all the yellow, stop. Then use a high quality wax. Chances are, you won't have to touch it for another 10 years. Can we see pic's of the finished product when yu get there. Would be helpful for all. Pat |
jonferns |
Jul 19 2007, 09:24 PM
The 3M stuff didnt do too much to affect it. I think im gonna try the turtle wax compound and see what that can do
Lo-Fi Version | Time is now: 5th May 2024 - 06:42 PM |
