Side Marker Lights, Here is my solution to the "warts" side marker lights |
Joe Owensby |
Jul 18 2007, 11:10 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
Here is what I did on my car to update the front side marker lights. I bought small LED (I think about 2" diameter) lights from a local FLAPS. I then opened up the existing hole in the front fender to match the outer diameter of the light. I welded up the existing bolt holes that were for the old "Warts", and then welded in a stud on each side of the light. Needs to be inside the fender enough to make sure it doesn't hit the front signal light assembly when it is installed. I will use a simple bar with holes in each end and nuts on the studs to clamp the light to the inside of the fender. The taper on the outer end of the light will fill in to match the hole in the fender, maybe with a little silicon seal on the inside to completely seal the hole. The lights will extend above the outer surface of the fender about 1/8 of an inch. Cost was about $10.00 each. The photos show the light temporarily in place to allow proper fitting as I final sand the fender. JoeO
bigkensteele |
Jul 18 2007, 11:55 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Those look really nice, and it looks like your work is top-notch. Where did you get the lights?
70Sixter |
Jul 19 2007, 10:02 AM
Member Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States |
That really is nice work. I went one step farther and welded the center hole up.
boxstr |
Jul 19 2007, 11:04 AM
If the body is being worked on and it is going to be painted, why not weld the holes up and be done with the warts.
CCLIN914NATION |
TROJANMAN |
Jul 19 2007, 12:00 PM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
JmuRiz |
Jul 19 2007, 12:53 PM
914 Guru Group: Members Posts: 5,427 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
If the body is being worked on and it is going to be painted, why not weld the holes up and be done with the warts. CCLIN914NATION (IMG:style_emoticons/default/agree.gif) |
ruddyboys |
Jul 19 2007, 01:03 PM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
I welded mine up and the side looks sooo much better. I remember seeing a post of someone installing I think a New VW side marker behind the wheel well, looked real good.
Joe Owensby |
Jul 19 2007, 06:14 PM
Lights were from Advance Auto.
I looked around here a lot, and saw several options, including the ones behind the wheel. I started to delete the lights all together. However, after several weeks of paying particular attention to the visibility of cars that I met at night, I noticed that the side lights really do make quite a difference in visibility. If a car was coming from a side road at a 90 degree or lesser angle, the side lights really made a difference in being able to see the car. So, I decided to compromise and keep the lights, but make them a little more acceptable, as I plan to drive the car a lot- if I ever get it done. Cheers, JoeO |
TROJANMAN |
Jul 19 2007, 06:36 PM
Did they pop right in, or did you have to do some improvising?
retrofit |
Jul 19 2007, 06:48 PM
Member Group: Members Posts: 176 Joined: 17-April 04 From: Turlock,Ca Member No.: 1,943 |
Here is what I did on my car to update the front side marker lights. I bought small LED (I think about 2" diameter) lights from a local FLAPS. I then opened up the existing hole in the front fender to match the outer diameter of the light. I welded up the existing bolt holes that were for the old "Warts", and then welded in a stud on each side of the light. Needs to be inside the fender enough to make sure it doesn't hit the front signal light assembly when it is installed. I will use a simple bar with holes in each end and nuts on the studs to clamp the light to the inside of the fender. The taper on the outer end of the light will fill in to match the hole in the fender, maybe with a little silicon seal on the inside to completely seal the hole. The lights will extend above the outer surface of the fender about 1/8 of an inch. Cost was about $10.00 each. The photos show the light temporarily in place to allow proper fitting as I final sand the fender. JoeO I like the look. At first glance it looks stock, but hey, somethings different. Should satisfy the purists, CW's, it's got the damn sidemarkers! Yet, you can see there is some subtle work here... To offend everyone make them strobe with warning sensors activating the strobe effect when a car approaches at a 90* with ill intensions... |
thomasotten |
Jul 19 2007, 09:24 PM
Senior Member Group: Members Posts: 1,545 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
Warts?
yeah, I'll admit they aren't the most streamlined item. But get yourself a new set and be proud of em. Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 07:22 PM |
