AXing & fiberglass front valance |
GaroldShaffer |
Jul 20 2007, 12:00 AM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
OK, my car is back from paint and almost together (IMG:style_emoticons/default/clap56.gif) This is a street car that is setup more AXing now. For now I put the stock steel front valance back on, but have been looking at the LE repo front valances. My concern is if I go with the LE valance, the few times I ever hit a cone (IMG:style_emoticons/default/cool_shades.gif) (IMG:style_emoticons/default/biggrin.gif) it will crack the valance, yes? I like the stock metal one because it can take the abuse, but I really like the looks of the LE valance.
So who runs with a LE valance? any issues? |
DanT |
Jul 20 2007, 12:17 AM
I've got a FG LE air dam and have had no issues other than the black paint chipping off. Have to touch it up after almost every event. (IMG:style_emoticons/default/sad.gif)
But at least no cracks so far.... mine is actually pretty flimsy...pretty old knock off. newer ones I have seen are molded in Black gelcoated FG and are much thicker and more rigid. |
URY914 |
Jul 20 2007, 08:22 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,389 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I used to run my car with the LE spoiler. Yes, if you hit something hard enough it will break and I'll have to fix it. So what? (IMG:style_emoticons/default/confused24.gif)
If you like the looks, put it on the car. You could always add some f/g to the back side to stiffen it up. |
J P Stein |
Jul 20 2007, 09:22 AM
Like Paul's my LE spoiler is a bit busted up. Dan prolly don't go fast enuff to break his.....or maybe he stays 2-3 feet away from the cones. (IMG:style_emoticons/default/happy11.gif)
DanT |
Jul 20 2007, 09:35 AM
Like Paul's my LE spoiler is a bit busted up. Dan prolly don't go fast enuff to break his.....or maybe he stays 2-3 feet away form the cones. (IMG:style_emoticons/default/happy11.gif) you just have to hit them at the correct angle (IMG:style_emoticons/default/biggrin.gif) |
grantsfo |
Jul 20 2007, 12:20 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Here is the most bullet proof spoiler made for our car the Bontempi spoiler. It cuts cones in two.
Attached thumbnail(s) |
Chris Pincetich |
Jul 20 2007, 12:41 PM
No problems with my LE, but I only hit cones with my rear tires. (IMG:style_emoticons/default/cool.gif)
All the cracks I've put it it were from collisions with concrete on low driveways and parking too close to high curbs. LE looks coolest (IMG:style_emoticons/default/beerchug.gif) |
brilliantrot |
Jul 20 2007, 08:08 PM
Member Group: Members Posts: 125 Joined: 27-April 07 From: Costa Mesa Ca. Member No.: 7,699 |
Mine has stood up incredibly well but I did manadge to put a small crack in it and the fiberglass rocker by hitting a cone at speed. Marietex fixed it up and matches the paint and have had no problems since.
Joe Ricard |
Jul 21 2007, 07:21 AM
Too bad you Street Prepared guys can'y run a splitter.
I fabbed up a splitter for my XP car it was nearly indestructable. cones would not go underthe car anymore which was good. I am going to make something lighter but same basic design. and a bit lower. |
Chris Pincetich |
Jul 23 2007, 11:02 AM
This weekend at Bay Meadows I would have won the Kone Killer award! There was a 2-cone slalom in a super tight spot....only the GGR folks bunched 3 cones together at each slalom point (IMG:style_emoticons/default/huh.gif)
My point is that my LE spoiler held up great after punching through about 20 cones this weekend (IMG:style_emoticons/default/beerchug.gif) |
914forme |
Jul 26 2007, 11:04 AM
I don't even run a spoiler or rocker panels or rear valance it is all weight. That being said I saw the pictures for the last event and my car looks like a true sh_tbox, so it is time to do a decent single color paint job, and add the rocker covers and LE front valance.
Let you know how if fairs against the cones, though I ussally don't hit them, unless I am spinning. BTW, the factory LEs had two braces that came down from the trunk floor to the lower lip, for extra support an LE Bra if you will, or Jock Strap |
914forme |
Jul 30 2007, 10:22 AM
No problems with hitting a cone with the valance. Id did it to avoid a DNF in a slamon I entered a little to hot on. Lets see +1 cone or a DNF, I will take hte cone thank you. Oh it was a ~40 MPH hit, cone punted, and corner worker got a work out on that one. Still trying to get the cone rool down. Where I can just rotate it right in the box.
I gotten the punt down good. The national level drivers can roll a cone in the box, watched Kent Weaver do it 4 times, this weekend. |
GaroldShaffer |
Jul 31 2007, 01:12 PM
Thanks guys. I'm going to stick with the metal one for now, but I will pick up LE sometime before winter.
Lo-Fi Version | Time is now: 5th May 2024 - 06:49 AM |
