> Weber IDA Carb, Carb Issues
Russ
post Jul 20 2007, 08:35 AM
Histroy:
Recently my "14" was left in the rain due to a surprise thunder strom. The car is a semi track car, so it does not have a rain gaurd, with that said you should now were this is headed. So far I have removed the carbs and disassembled them, cleaned out the water, and reassembled the units, and reattached to the motor. Fired the car up and went for a test drive.
The problem:
With the car warmed-up and traveling at a steady velocity/ RPM ( 3000< RPM) the car is spitting/ or miss firing and when the accelerator pedal is released there is a great deal of popping thru the exhaust.
Any help or suggestions would be greatly appreciated.
Russell Turpin
803-606-7269
turpin0801@aol.com
Attached File(s)
Attached File  Fat_Type_IV_Engines_1.pdf ( 44.31k ) Number of downloads: 123
DonTraver
post Jul 20 2007, 08:50 AM
You said IDA carbs, so I will assume a 6. What kind of ignition,CDI? If it is, the harness plug to the CDI module can get wet and will cause all kind of missfiring and popping. Check all your connections, blow out with air, pull dist cap and dry. I always had to wrap the module when washing the car or all that would happen. The CDI ignition is/was the biggest continuing problem I had with my 6, finally trashed it and went MSD, no more problems.
Russ
post Jul 20 2007, 09:50 AM
QUOTE(DonTraver @ Jul 20 2007, 09:50 AM) *
The engine is a 2.4L FAT Four. The ingnition is MSD.
Thanks for the suggestions. I have not thought about wet connetions. Some times the simplest things can drive you crazy.
Thanks again
Russ
post Jul 20 2007, 09:53 AM
My bad. I typed IDA, but ment IDF Weber.
JoeSharp
post Jul 20 2007, 10:10 AM
In Irvine, Ca. May 15-18
Check your idle jets and Sync the carbs.
URY914
post Jul 20 2007, 11:01 AM
I had a puddle of water show up in the bowl of one of my IDF's. Strange but true.
Try looking there by removing the top of the carb.
rhodyguy
post Jul 20 2007, 05:37 PM
check for moisture in the distributor cap and around the point retaining plate in general, and the wire ends at the plugs and the cap. check timing. i don't think water is going to get into the float bowls or clog idle gets bcause the engine got wet. try a shot of water displacement formula number 40 in the suspect areas.
k
JPB
post Jul 20 2007, 08:00 PM
The Crimson Rocket smiles in your general direction.
Did ya tighten them down good on the intakes and use new gaskets? (IMG:style_emoticons/default/beer.gif)
Russ
post Jul 20 2007, 09:33 PM
Thanks for all the suggestions. I'll givem a try and let you know which one solves the problem.
- Lo-Fi Version Time is now: 2nd July 2025 - 01:22 PM
