944 turbo advice needed, wastegate |
scotty b |
Jul 21 2007, 10:11 PM
So my turbo engine arrived and upon inspection I find the wastegate is SHOT. I am planning on a "mild" 2809-300 h.p. engine using bolt ons for the most part. My question is should I opt for a tial or lindsey wastegate or just replace it with a stocker?? Used stock one can be had for under 100.00 whereas the others $$$$$$ What is the advantage to the $$ ones other than less boost blown off? Aside from that problem the engine supposedly has 86,000 miles, I turned it over by hand (socket) and it has GOOD compression. I will be checking it for leakdown later this week or next. VERY clean but not cleaned. Where is that fingers crossed smilie (IMG:style_emoticons/default/idea.gif)
iamchappy |
Jul 21 2007, 10:17 PM
Go with what you can afford or wish to do with the car, if you plan on improving on it, a new wastegate looks to be a start in the right direction.
73Phoenix20 |
Jul 22 2007, 09:45 AM
Member Group: Members Posts: 334 Joined: 15-June 05 From: Michiana Member No.: 4,283 |
Lindsey Racing Adjustable Wategate...
IF you want to see 300 ponies... |
scotty b |
Jul 23 2007, 08:12 PM
Lindsey Racing Adjustable Wategate... IF you want to see 300 ponies... Yeah that's pretty much what I have decided on. They actually sell their dual port wastegate and a 3" exhaust kit for about a grand. That allows me to upgrade the turbo to a 26/8,chip,intake,adjustable fuel pressure etc. and do some other small upgrades. I'm figuring around 300 at the wheels. (IMG:style_emoticons/default/driving.gif) http://www.lindseyracing.com/mm5/merchant....AGEDEALSEXHAUST |
73Phoenix20 |
Jul 23 2007, 09:13 PM
And Dave Lindsey is a super nice and very sharp supplier to work with!!!
VaccaRabite |
Jul 23 2007, 09:51 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I am planning on a "mild" 2809-300 h.p. engine using bolt ons for the most part. Wow. I knew 951s were pretty rock'n, but nearly 3K HP with bolt ons is pretty awesome! (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/happy11.gif) Zach |
scotty b |
Jul 24 2007, 07:04 PM
[quote name='Vacca Rabite' date='Jul 23 2007, 07:51 PM' post='927252']
(IMG:style_emoticons/default/cool.gif)--><div class='quotetop'>QUOTE(scotty b @ Jul 22 2007, 12:11 AM) </div><div class='quotemain'><!--quotec--> I am planning on a "mild" 2809-300 h.p. engine using bolt ons for the most part. [/quote] Wow. I knew 951s were pretty rock'n, but nearly 3K HP with bolt ons is pretty awesome! (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/happy11.gif) Zach [/quote] (IMG:style_emoticons/default/dry.gif) Don't you have some wet sanding to do junior? I'm gonna start sending you a box of oranges every week (IMG:style_emoticons/default/laugh.gif) |
Wide914 |
Jul 25 2007, 06:47 AM
Newbie Group: Members Posts: 25 Joined: 24-April 06 From: Toronto, On - Vancouver, BC Member No.: 5,917 Region Association: None |
Lindsey is a good choice, but Tial 38mm DP wastegate with the SFR adapter cant be beat
Lo-Fi Version | Time is now: 18th May 2024 - 10:24 AM |
