Tuesday, 23 September 2025 |
trojanhorsepower |
Senior Member ![]() ![]() ![]() Group: Members Posts: 951 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None ![]() |
Any one ... any one ... Buler?
Mine are the allen head kind. Thanks -Pete |
trojanhorsepower |
I found it 20 ft lbs if any one wanted to know.
-Pete |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
How far along is the re-do?
M |
trojanhorsepower |
I have finished tearing everything apart and I posted the #'s for Jake to match up the bearings. Throwing caution to the wind I went ahead and assembled the crank (cleaned everything and matched the bearings back up and got the caps all on there right). If Jake says they are the wrong bearings than I will just take it all apart again.
I called CB and got the torque for the cam gear so I will bolt that on shortly and set the cam timing. If I get the OK form Jake I will put the case back together tonight and start getting all the through bolts set up. May not torque them down till tomorrow, but we shall see. If I can ever get rolling I could have the motor back to long block in a few hours. -Pete P.S. Redshift, I bet you wish you hadn’t asked now. |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
I need more numbers. call me.
torque the bolts to 18 lb/ft and use red loctite |
HarveyH |
Member ![]() ![]() Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 ![]() |
Be VERY SURE to use the Loctite. The PO's builder didn't. (IMG:style_emoticons/default/mad.gif) Bolts walked out, ate the oil pump, strange noises, metal shavings in the engine, BAD! (IMG:style_emoticons/default/headbang.gif) BAD! (IMG:style_emoticons/default/headbang.gif) BAD! Evil thoughts upsetting my karma (IMG:style_emoticons/default/ar15.gif)
Harvey |
trojanhorsepower |
HarvyH
Yep, I did. My PO went the other way though, he used JB Weld!!! I had to use some heat to get them out so I could put the gear on right. -Pete |
Lo-Fi Version | Time is now: 22nd September 2025 - 08:29 PM |
