bolt-on flares, lookin for pics |
BravoHotel |
Dec 16 2003, 11:09 AM
Member Group: Members Posts: 153 Joined: 5-March 03 From: Columbus, MS Member No.: 399 |
I like the look (and ease of replacement) of the bolted-on GT flare. Does anyone have detailed (up-close) pics of this treatment? What size/number/type of screws or bolts were used.
Please post pics Thanks BH Attached image(s) |
BravoHotel |
Dec 16 2003, 11:10 AM
BTW, that car (IMG:style_emoticons/default/agree.gif) belongs to Brett W.
Or how about this one....does it belong to anyone here? Attached image(s) |
Gint |
Dec 16 2003, 11:15 AM
Mike Ginter Group: Admin Posts: 16,066 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
The white one is Scott Schroeder's car. He's on the board.
BravoHotel |
Dec 16 2003, 11:16 AM
Scott,
Can you give us details? BH |
Ferg |
Dec 16 2003, 11:17 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Randal |
Dec 16 2003, 12:28 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
I think most of what people refer to as “bolt on” flares are actually riveted. The rivets I used were 3/16"dia. by 3/4" long, measured from the top of the rivet to the bottom of the shoulder.
If your building a race car check out High Performance House's flare system. Attached image(s) |
john rogers |
Dec 16 2003, 12:52 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I put riveted flares on my race car and learned several things: Use "large head" rivets, available from Racer Parts Wholesale and a backing washer so they will not pull loose. Get a pneumatic riveter such as the low cost one from Harbor Freight as it is much easier to use than a manual one. Get a couple of packs of the right size Cleco fasteners and a pair of the Cleco pliers from Racer Parts to hold them on with as you drill all the holes. Install the flared rocker panels on first using the jack point opening as a locator then fit the flares to mate with the ends of the rocker panels. Oh yea, the large head rivets also come in colors besides natural aluminum. Good luck
BravoHotel |
Dec 16 2003, 08:38 PM
bump....still lookin for pics
Gint |
Dec 16 2003, 10:19 PM
I'll email Scott and ask him to stop by here...
Scott S |
Dec 17 2003, 11:12 AM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
Hi All -
I unfortunately do not have pics on my office computer, I will post some this evening. Mine are bolt on - no rivets. The gasket I used between the flare and the body is a "heavy duty" vw bug fender gasket. The heavy duty moniker gives toy a bigger bead. They were super cheap - like 10.00 for the whole car. The flares use a stainless rounded button head phillips machine screw on a hard rubber washer. Undernieth is a small fender washer and nylock nuts. This was what the guys at Better Bodies told me they were using on their GT2 body kits. I did mine this way as I loved the look of the old 934, and I simply dont trust the adhesives in terms of future cracks (we had a 70 degree temp swing here in less than 6 hours - and that is not uncommon). I have had them off several times - it makes strut/shock and brake work SO easy. Sorry for the delay - again, check back later tonight tomorrow. Scott S |
Scott S |
Dec 17 2003, 11:14 AM
Here is the tops - kind of a distant pic. More tonight....
Attached image(s) |
BravoHotel |
Dec 17 2003, 11:55 AM
QUOTE(Scott Schroeder @ Dec 17 2003, 09:12 AM) I did mine this way as I loved the look of the old 934... I have had them off several times - it makes strut/shock and brake work SO easy. Scott, thanks for the info (IMG:style_emoticons/default/agree.gif) Totally! The "bolted-on" treatment looks so business like (IMG:style_emoticons/default/aktion035.gif) I like the idea of being able to remove for brake/suspension maintenance.. Did you use the "flared" rockers as well? Where did you purchase your flares? The prices at www.rennspd.com seem very reasonable. Anyone have experience w/ them? Did you have to do any trimming on the fiberglass or just prep/paint & bolt-on? I'd like to see some close-ups of the rocker/flare interface Thanks! BH |
Scott S |
Dec 17 2003, 12:42 PM
I bought one from Performance Parts, two from Pelican and one from GT racing due to everyone having inventory issues. Yes, they required a great deal of prep work. Each flare had a different shaped flange where they met the body. I spent several hours using a big upright drum sander to get them the same. I was also surprised at how many pin holes and imperfections there were in a couple of them. So, yeah, lots of the typical fiberglass finish time to get them "right". I am still not completely satisfied - but I am pretty anal.
Yes, I have the normal GT flared rockers. I am a big believer that you have to have these to get the flares on the car correctly. I mounted them on the car first before I did anything else with the fenders - especially the cutting! |
SirAndy |
Dec 17 2003, 02:55 PM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Scott Schroeder @ Dec 17 2003, 10:42 AM) I am a big believer that you have to have these to get the flares on the car correctly. I mounted them on the car first before I did anything else with the fenders - especially the cutting! that's the only way to go if you want to fit your flares right. the rockers give you a point of reference ... Andy |
Eric_Shea |
Dec 17 2003, 03:10 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE The prices at www.rennspd.com seem very reasonable. Anyone have experience w/ them DON'T DO IT! I bought both bumpers, valance and rockers from them. Every single piece had to be cut and reworked. I have other glass pieces on my car and I got them from Mark Bartosh (classifieds in Pano). My flares came from AIR. Marks stuff is the best. AIR is good. I say this because I want you to know that I realize "all glass" will need "some" work. Rennspeeds stuff needs some "MAJOR" work. At least the batch I got... Rennspeed breakdown: Front bumper - Two left mounts glassed into the bumper. Had to cut the right on and reweld it. Valance - Hung out 1"+ on each side. Had to cut a "v" and reglass them. Serious PITA. Rear Bumper - Had to grind out copiuos amounts from each corner where the car meets the bumper... still finalizing the fit on that one (working front to back) Rockers - concave curve on the top. I will glass in a hinge at the back to emulate the rally car rockers and eliminate the problem with the front fitting and the back side being about 1/2" too high! Need pictures or was that scary enough? E. P.S. I don't want to harp but that was my experience. If any others have had better luck please weigh in... |
BravoHotel |
Dec 17 2003, 03:20 PM
well, it sounds like w/ rennspd, you get what you pay for....
Are AIR's flares (hey, that rhymes (IMG:style_emoticons/default/idea.gif) ) similar in price to Mark's stuff? |
Eric_Shea |
Dec 17 2003, 03:29 PM
I think Mark's a little less expensive. I don't know if he has flares though. I got both hoods from him and all my 911 RS stuff (ducktail, hood, bumpers). I'm thinking about getting 914 doors from him... not sure if I want to go glass on those though.
E. |
Brad Roberts |
Dec 18 2003, 03:00 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Um.. I have yet to see a replica rocker that was correct. I dont personally suggest using the F/G rocker as a guide to do anything.
B |
joea9146 |
Dec 18 2003, 10:31 AM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
Brandon12 |
Jan 25 2013, 06:06 PM
Newbie Group: Members Posts: 1 Joined: 25-January 13 From: Ohio Member No.: 15,425 Region Association: North East States |
Hey I just started a restoration for my father and I was wondering what websites to get bolt on flares and I need to know how to do it
Lo-Fi Version | Time is now: 5th May 2024 - 09:44 PM |
