| Joe Bob |
Dec 16 2003, 01:41 PM
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Blondie has an issue with camber....the left rear MAY be bent.....how can you tell if it's still on the car?
| ArtechnikA |
Dec 16 2003, 01:43 PM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
QUOTE(mikez @ Dec 16 2003, 11:41 AM) ...the left rear MAY be bent.....how can you tell if it's still on the car? if it's not on the car, you can tell right away ! (bada-boom!) |
| JFJ914 |
Dec 16 2003, 01:53 PM
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States
You sort of work it backwards, If you can get the stock camber adjusted with approx three shims and stock length bolts it's not bent. The more shims needed, the more bent it is. If you think it's bent, it probably is. Same for tow, if you can't get there it's bent.
| Brad Roberts |
Dec 16 2003, 01:57 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
I agree with John.
It is bent. B |
| echocanyons |
Dec 16 2003, 05:14 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,119 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California
I belive there were stock measurements in the haynes for the control arms this may help to see if it is bent.
dunno how accurate Haynes numbers are though (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 10th November 2026 - 08:51 PM |
