Zaney |
Deuchland en der Haus ![]() ![]() Group: Members Posts: 461 Joined: 1-March 04 From: Engine 11 Redmond, WA Member No.: 1,738 Region Association: Pacific Northwest ![]() |
After making the swap to Engman's wonderful new fuse panel I only have one gremlin to chase down. Using Haynes electrical diagram with a 1974 USA teener I have narrowed it down to the Fog Light relay. Previously, the relay worked fine however, in reconnecting the relays into the new panel a short has developed.
Is it possible for the connections to come loose in the relay connector? Or am I barking up the wrong tree? I think I have it narrowed down to the #30 wire which is the red/black wire connected with the #30 red wire from the horn relay. (Horn doesn't beep either only relay clicks) These two wires connect to fog light portion of the panel. What is the next step? I have tried different relays with the same result- LED fuse lights up when fog light switch is pulled on. (IMG:style_emoticons/default/help.gif) Any suggestions are very welcome! Thanks! |
Lo-Fi Version | Time is now: 11th June 2024 - 07:56 AM |
