V8 Guys - Front Air Exhaust Cutouts, Wire Screen Ideas |
tyler |
Jul 28 2007, 09:33 AM
Member Group: Members Posts: 335 Joined: 24-September 03 From: southern california Member No.: 1,192 |
While I'm putting in my 911 front end seems like the time to finally get some kind of wire over these big gaping holes. I've seen a pattern of holes drilled instead of the big cutout that looked pretty good but it's too late for me now.
Anyone got pictures of a nice wire finish job on these cutouts? |
Dr. Roger |
Jul 28 2007, 03:57 PM
Keep in mind that once those holes are made, your car now becomes a "no rain/no puddles" car.
have you considered a through-the-hood option? |
Crazyhippy |
Jul 28 2007, 07:07 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
ah yes, a big hole in the hood makes it a much better car to drive in the rain... 99% of the rain i've seen comes from above (IMG:style_emoticons/default/WTF.gif)
The fender cutouts really dont need anything over them. adding in expanded sheetmetal will keep any critters out, but it doesn't do anything for strength, and the water still get in. I'm on my 4th 914, 3rd watercooled w/ fender cutouts and have never felt the need for any semblance of cover. Like w/ most conversion related things, Renegade Hybrids has what you are looking for... (IMG:http://renegadehybrids.com/914/Customers/RalphK/Pic06.jpg) BJH (IMG:style_emoticons/default/biggrin.gif) |
tyler |
Jul 29 2007, 09:38 AM
The holes have been in for some time and this is not only a "no rain/no puddles" car, but also a "no wet wash car".
tyler |
Jul 29 2007, 09:42 AM
This isn't for strength, cosmetic only. It look a little unfinished with the open holes, plus stash in the trunk can fall out on the road.
I think wire will probably be better for airflow and I don't think Renegade is the place to buy wire, even if it's cut to fit. |
skline |
Jul 29 2007, 09:44 AM
I think the expanded metal is probably your best bet, it can be painted to match, or flat black even or you could get the stainless and be done with it.
dakotaewing |
Jul 29 2007, 01:20 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
One of the screens I am considering using for my car is the screen used on wire trash cans - I found one at Ikea recently for $4
My only concern is that the wire my be too fine, and restrict airflow too much - You would need 2 cans - 1 for each side of the car - Attached image(s) |
Crazyhippy |
Jul 29 2007, 03:20 PM
That picture is expanded sheet metal, painted to match the rest of the trunk/car.
Home Depot (Hi Trekkor) carries pieces big enough to do this. Renegade happened to have the picture you asked for though (IMG:style_emoticons/default/wink.gif) BJH (IMG:style_emoticons/default/biggrin.gif) |
McMark |
Jul 29 2007, 03:27 PM
Thom, I like that fine mesh. Yes it will restrict air, but I'd place my bet that it would be fine regardless.
I like welding in wire mesh. (IMG:style_emoticons/default/happy11.gif) (IMG:http://www.paintandmetal.com/invoice/images/large_images/23_042340300%201148343057.jpg) |
dakotaewing |
Jul 29 2007, 05:34 PM
Thom, I like that fine mesh. Yes it will restrict air, but I'd place my bet that it would be fine regardless. I like welding in wire mesh. (IMG:style_emoticons/default/happy11.gif) (IMG:http://www.paintandmetal.com/invoice/images/large_images/23_042340300%201148343057.jpg) I was actually going to "frame" the mesh with another piece of sheet metal on the inside of the fender well - That mesh may be too"fine" to tack weld, so I would use high strength epoxy to connect the mesh to the frame - (4000 lb tensel), and either tack weld or screw in the "frame" with the attached mesh - |
Jul 29 2007, 05:44 PM
Resident German Group: Admin Posts: 41,654 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
ah yes, a big hole in the hood makes it a much better car to drive in the rain... 99% of the rain i've seen comes from above (IMG:style_emoticons/default/WTF.gif) let me spell this out for'ya: S H R O U D it's really not at all that hard. many modern cars do that too. you know, the ones that come with a Wasserpumper V8 (or similar) from the factory ... (IMG:style_emoticons/default/rolleyes.gif) Andy |
Lo-Fi Version | Time is now: 24th May 2024 - 11:23 AM |
