o.k. this is for you swivel foot .060 removal vets, need experianced advice |
orange914 |
Jul 31 2007, 08:55 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
i'm relitively sure you remove .060 from the base of the foot pad itself... right? i just took to the machine shop and now after questions i'm second guessing it. they seemed to think removal at the bottom of the rocker is the .060 removal area. i think that could either affect the valve geomitry or the threads would be .060 further up into the hole -meaning less threaded area in the rocker. i just need confirmation before doing .060 off the pad. (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/confused24.gif)
by the way what kind of $ has this cost others? we talked and the machinist thought the best way to remove .060 was to use a tubular peice that is threaded to hold the swivel foot in the valve stem lathe. |
Lo-Fi Version | Time is now: 28th May 2024 - 03:18 PM |
