Rear Sway Bar Mounts |
Engman |
Dec 17 2003, 05:55 PM
Zoisite Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
Engman |
Apr 13 2004, 01:10 PM
I also have the trunk reinforcements for the rear sway bar mounts. Engman Parts has all the details.
M |
SirAndy |
Apr 13 2004, 02:31 PM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
cool! do you also have brackets for mounting the sway bar inside the trunk, like they did on the GT's?
Andy |
Engman |
Apr 13 2004, 02:32 PM
I am ignorant on that one. Is there a pic somewhere?
M |
SirAndy |
Apr 13 2004, 05:06 PM
QUOTE(Engman @ Apr 13 2004, 01:32 PM) I am ignorant on that one. Is there a pic somewhere? here you go ... Attached image(s) |
914werke |
May 17 2004, 09:18 AM
"I got blisters on me fingers" Group: Members Posts: 10,049 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
How about a pic of the trunk reinforcements and another of thier installed location?
Engman |
May 17 2004, 03:40 PM
Here is a pic of the reinforcements....
Attached image(s) |
Engman |
May 17 2004, 03:41 PM
And the location is easy - right againt the rib at the top on each side... Shown is the drivers side shot from the rear...
Attached image(s) |
Engman |
May 19 2004, 01:35 PM
Andy - here is borrowed pic of what I think you are referring to.
M Attached thumbnail(s) |
Engman |
Sep 20 2004, 04:44 PM
Attached image(s) |
monkei |
Sep 28 2004, 10:18 PM
slave to rust.... Group: Members Posts: 137 Joined: 10-August 04 From: Pleasanton, CA Member No.: 2,504 |
can the top still fit in the rear trunk with the sway bar installed as shown above?
Engman |
Sep 28 2004, 10:28 PM
The in trunk mount has not been made and is not currently available. This was a discussion Andy had on the subject a while back. If it WAS available it would not interfere with the top - too much distance between the two.
M |
monkei |
Sep 28 2004, 11:05 PM
thought that looked odd, how does it mount then: from trailing arms or a arms to the reinforced trunk mount? you have any pictures of a rear sway bar setup installed with the brackets? this would be used with stock rear bars?
Lo-Fi Version | Time is now: 7th May 2024 - 06:07 PM |
