Now that's it's running, couple questions |
BahnBrenner914 |
Aug 2 2007, 01:44 AM
The girl is gone and all I have now is a beat-up teener Group: Members Posts: 301 Joined: 22-May 04 From: Gig Harbor and University Place, WA :: School in Angola, IN :: girlfriend in Sarasota, FL Member No.: 2,094 Region Association: None |
So my teener ('76 2.0) is now driveable so I've been buzzing around (IMG:style_emoticons/default/driving.gif) and it's been quite enjoyable (IMG:style_emoticons/default/w00t.gif) . But there's a couple issues.
How high on the temp gauge (oil) should it run regularly? I haven't been driving it more than about 20 miles at a time, but it's gotten up to half way and then I was at my destination. Am I just being overly cautious? I'm cruising around between 2 and 4 K on the revs. Should I be closer to 4 for more air flow, or is 2 to 3 ok? Should I be able to hear the fuel pump whining? I only hear it whining sometimes. I've had an intermitent bog down of power, usually in 3rd gear. It's when I give it throttle at 2 or 3K rpm, it bogs for a second and then pics back up. It doesnt happen all the time, just sometimes. I also have weird idle issues. I've had it die on me a couple times when cold, hunting idle, high idle (1500 or so). Its usually ok, just a few times I've had the issues (maybe 10% ) |
Joe Ricard |
Aug 2 2007, 06:23 AM
I'm guessing your car still has Fuel injection.
Bog can be from going lean just as you open the throttle. One of the D-jet bubbas shuld be along soon to tell you about the TPS. I Normally runn 2500 RPM minimum cruise on the freeway 3200. I just don't know what the gauge translates to so I got a VDO oil temp gauge with matching sender. 180-220 is fine. You could check your oil cooler for dirt and crud. underneath the car shine a flash light up through it. |
rhodyguy |
Aug 2 2007, 08:21 AM
i think you're lugging your engine a bit. i roll @ 3.k at a minimum. appropriate gear, no matter how fast you're going.
k |
BahnBrenner914 |
Aug 2 2007, 12:14 PM
ah, Justification for driving faster (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/w00t.gif)
rhodyguy |
Aug 3 2007, 08:04 AM
no... wrong. correct gear for the legal speed. also, stay off I-5 when traffic is choked. use priority surface roads.
k |
Lo-Fi Version | Time is now: 19th May 2024 - 08:53 AM |
