911 Front Suspension Upgrade, Long Studs on Wheel Hub |
tyler |
Aug 2 2007, 08:45 AM
Member Group: Members Posts: 335 Joined: 24-September 03 From: southern california Member No.: 1,192 |
I'm in the process of installing an '80 911SC front end on my '70 914 for the brake upgrade. I notice the lugs on the 911 hub are extremely long. I didn't worry about this since I figured I'd see where the wheels end up under my flares and either use a spacer or trim the lugs. Now I'm wondering if these long lugs are for something special and it might be worth something to someone to swap them for short lug hubs (if they exist) instead of trimming them off.
Anyone familiar with these long 911 hub lugs? |
skline |
Aug 2 2007, 08:51 AM
Long studs are for running as you mentioned, spacers. If you don't need them, they should be sold or traded for what you need rather than to cut them down.
tyler |
Aug 2 2007, 09:04 AM
Thanks, I'll post an ad. I thought that might be the case. Any idea if they're worth anything of should be a straight trade?
skline |
Aug 2 2007, 09:08 AM
The value is at best a few bucks difference, I would check PP and see what the difference is and go from there. If it were me, I would probably just find someone who would trade you.
skline |
Aug 2 2007, 09:12 AM
Going by PP site, the stock 45mm thru 67mm are 7.25 and 72mm are 7.50 and the 100mm are 9.15 so it's only a few bucks difference.
davep |
Aug 2 2007, 11:15 AM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
It is almost better to do a straight swap. Be sure you get the hubs you need; there are a few variations there also. I think the fewer the times the studs are replaced the better.
Aug 2 2007, 12:27 PM
Resident German Group: Admin Posts: 41,658 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
or just use 'em ...
i have 100mm studs front/rear and a whole bunch of different size spacers. never have to worry about different wheel offsets again. i have three sets of wheels with different offsets and all i have to do is switch spacers to run another set. very convenient. (IMG:style_emoticons/default/bye1.gif) Andy PS: just make sure you use the open end steel lugnuts, the aluminum lugnuts will break if put on a stud that is too long. |
cobra94563 |
Aug 2 2007, 03:17 PM
Chris Group: Members Posts: 341 Joined: 1-March 05 From: San Francisco Member No.: 3,696 |
if you end up interested in a trade, let me know. i have a 83(?) sc front end with standard length studs.
I want to go 1in wider, but haven't decided on spacers, adapters, or maybe 8in wheels. |
Lo-Fi Version | Time is now: 27th May 2024 - 07:27 PM |
