| r_towle |
Mar 15 2003, 05:24 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
So,
I want to stop shifting so much at the Autocross. What gears would you all recommend??? Rich |
r_towle AX transmission Mar 15 2003, 05:24 PM
ChrisReale Not a professional answer (ill leave that to the "... Mar 15 2003, 06:15 PM
Zeke In that case, Chris, I think you're friend has... Mar 15 2003, 06:42 PM
J P Stein I would like an A or B first. We are pretty much S... Mar 15 2003, 07:57 PM
ChrisReale Zeke, he IS going faster than me, by about ten f... Mar 15 2003, 08:50 PM
J P Stein <... Mar 19 2003, 08:33 PM
porsche735 Rich,
As I said, no gears to buy. All you do is m... Mar 19 2003, 09:24 PM
Brad Roberts I normally use the terms (Drive and Driven gears) ... Mar 19 2003, 09:35 PM
Brad Roberts Richard,
We flip 5th gear to make a new shorter 3... Mar 19 2003, 10:52 PM
Mike T
drew365 This sounds like a good mod for a short road cours... Mar 20 2003, 09:46 AM
Joseph Mills I've been given two spare trannys from an ex-r... Mar 20 2003, 10:18 AM
Brad Roberts Joseph.
Flip a 5th from the tranny you want to us... Mar 20 2003, 11:08 AM
Brad Roberts Oh,
we chat about this like it is nothing. NONE o... Mar 20 2003, 11:10 AM
James Adams Gear chart for about a stock diameter tire (calcul... Mar 20 2003, 11:19 AM
Zeke
Travis Neff So, for a hot street setup - you would want to obt... Mar 20 2003, 01:19 PM
TimT Brad
I took the liberty to play with the pic yo... Mar 20 2003, 03:58 PM
TimT oops helps to attach the pic Mar 20 2003, 04:03 PM
Zeke I just did this and that's exactly what it loo... Mar 20 2003, 04:31 PM
bpick84 It will run okay in reverse cut, but it may whine ... Mar 21 2003, 09:35 AM
Zeke No one is gonna explain to me what "delta" is (I t... Mar 21 2003, 10:46 AM
Mueller 3.09-1.89=1.2
1.2/3.09=39% differance (delta)
1.8... Mar 21 2003, 11:13 AM
Demick I think the picture in Tim's post above shows ... Mar 21 2003, 12:04 PM
Brad Roberts Bill Pickering ?? If that is you... welcome. Thank... Mar 21 2003, 12:17 PM
r_towle I am close to understanding this...please forgive ... Mar 21 2003, 05:33 PM
TimT
Zeke <... Mar 21 2003, 05:53 PM
Demick Rich
Drive gears are always on the input shaft, d... Mar 21 2003, 06:05 PM
Brad Roberts It wasnt designed for it, but I personally have be... Mar 21 2003, 06:22 PM
TimT I wondered about the thrust issue. Then being an e... Mar 21 2003, 06:38 PM
porsche735 Back to this stock 5th thing.... Why would you wa... Mar 21 2003, 07:08 PM
TimT Milt did you get that spreadsheet I sent your way... Mar 21 2003, 07:24 PM
Racer Chris
Brad Roberts Chris,
The thread started out as a AUTOX thread..... Mar 21 2003, 11:49 PM
TimT Chris, I just bought the GT4 car, havent turned a ... Mar 22 2003, 08:31 AM
Racer Chris
TimT Chris I know your were teasing just wanted to use ... Mar 22 2003, 06:28 PM
mskala This may not apply to many, but for PCA
AX in our ... Mar 22 2003, 06:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 01:18 AM |
