> AX transmission
r_towle
post Mar 15 2003, 05:24 PM
Post #81
Custom Member
So,
I want to stop shifting so much at the Autocross.
What gears would you all recommend???
Rich
r_towle   AX transmission   Mar 15 2003, 05:24 PM
ChrisReale   Not a professional answer (ill leave that to the "...   Mar 15 2003, 06:15 PM
Zeke   In that case, Chris, I think you're friend has...   Mar 15 2003, 06:42 PM
J P Stein   I would like an A or B first. We are pretty much S...   Mar 15 2003, 07:57 PM
ChrisReale   Zeke, he IS going faster than me, by about ten f...   Mar 15 2003, 08:50 PM
J P Stein   <...   Mar 19 2003, 08:33 PM
porsche735   Rich, As I said, no gears to buy. All you do is m...   Mar 19 2003, 09:24 PM
Brad Roberts   I normally use the terms (Drive and Driven gears) ...   Mar 19 2003, 09:35 PM
Brad Roberts   Richard, We flip 5th gear to make a new shorter 3...   Mar 19 2003, 10:52 PM
Mike T
  Mar 20 2003, 08:19 AM
drew365   This sounds like a good mod for a short road cours...   Mar 20 2003, 09:46 AM
Joseph Mills   I've been given two spare trannys from an ex-r...   Mar 20 2003, 10:18 AM
Brad Roberts   Joseph. Flip a 5th from the tranny you want to us...   Mar 20 2003, 11:08 AM
Brad Roberts   Oh, we chat about this like it is nothing. NONE o...   Mar 20 2003, 11:10 AM
James Adams   Gear chart for about a stock diameter tire (calcul...   Mar 20 2003, 11:19 AM
Zeke
  Mar 20 2003, 12:51 PM
Travis Neff   So, for a hot street setup - you would want to obt...   Mar 20 2003, 01:19 PM
TimT   Brad I took the liberty to play with the pic yo...   Mar 20 2003, 03:58 PM
TimT   oops helps to attach the pic   Mar 20 2003, 04:03 PM
Zeke   I just did this and that's exactly what it loo...   Mar 20 2003, 04:31 PM
bpick84   It will run okay in reverse cut, but it may whine ...   Mar 21 2003, 09:35 AM
Zeke   No one is gonna explain to me what "delta" is (I t...   Mar 21 2003, 10:46 AM
Mueller   3.09-1.89=1.2 1.2/3.09=39% differance (delta) 1.8...   Mar 21 2003, 11:13 AM
Demick   I think the picture in Tim's post above shows ...   Mar 21 2003, 12:04 PM
Brad Roberts   Bill Pickering ?? If that is you... welcome. Thank...   Mar 21 2003, 12:17 PM
r_towle   I am close to understanding this...please forgive ...   Mar 21 2003, 05:33 PM
TimT
  Mar 21 2003, 05:38 PM
Zeke   <...   Mar 21 2003, 05:53 PM
Demick   Rich Drive gears are always on the input shaft, d...   Mar 21 2003, 06:05 PM
Brad Roberts   It wasnt designed for it, but I personally have be...   Mar 21 2003, 06:22 PM
TimT   I wondered about the thrust issue. Then being an e...   Mar 21 2003, 06:38 PM
porsche735   Back to this stock 5th thing.... Why would you wa...   Mar 21 2003, 07:08 PM
TimT   Milt did you get that spreadsheet I sent your way...   Mar 21 2003, 07:24 PM
Racer Chris     Mar 21 2003, 11:17 PM
Brad Roberts   Chris, The thread started out as a AUTOX thread.....   Mar 21 2003, 11:49 PM
TimT   Chris, I just bought the GT4 car, havent turned a ...   Mar 22 2003, 08:31 AM
Racer Chris     Mar 22 2003, 05:29 PM
TimT   Chris I know your were teasing just wanted to use ...   Mar 22 2003, 06:28 PM
mskala   This may not apply to many, but for PCA AX in our ...   Mar 22 2003, 06:57 PM
- Lo-Fi Version Time is now: 9th June 2026 - 01:18 AM
