Engine bay seals-door seals |
914werke |
Oct 10 2007, 09:46 PM
"I got blisters on me fingers" Group: Members Posts: 10,027 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
RE: the bulb kit can you provide more desc. & or Pic's?
Do they work witht the fader of the OE light switch? |
Mikey914 |
Oct 10 2007, 11:28 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
RE: the bulb kit can you provide more desc. & or Pic's? Do they work witht the fader of the OE light switch? The LEDs on the bulb kit are straight replacements for the bayonet bulbs that are in the car stock. Literally as simple as changing the bulb, no sodering or extra wirring. The LEDs do not dim. The are either on or off. They work with the factor fader switch to either be on or off. If you have an issue with night blindness, I would recommend the red kit as the red light will allow for better with white light vision (similar to aircraft cockpit night lighting). |
kconway |
Oct 18 2007, 11:35 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
[quote name='Mikey914' date='Aug 3 2007, 09:21 PM' post='931439']
Figured I'd add to the other seal thread to keep everything together. Just cut the die for the other 3 engine seals and have sample material back. I've checked it out and it fits as good as the original. I'm selling a strip that is cut in the field to fit. You would need less than 100" to do all 3, I'm sending at least 102" to allow for any variation. Okay, spent the money for the single rear seal and just need the two side seals. Don't tell me I gotta buy the whole 102"... |
Mikey914 |
Oct 19 2007, 02:53 AM
No, I'll break up a seal if you want 2 pieces. Both sides for $20 each, $40 + shipping.
boxstr |
Nov 7 2007, 11:32 AM
I need another engine seal, the complete roll for three sides. mAR k I PP'd funds.
Thank you Craig |
computers4kids |
May 13 2008, 11:19 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
Mark,
I could use a top engine bay seal and the roll to take care of the bottom three. I would also like a set of the "inner door" seals...the ones that attach to the door..not the frame. Do you by chance make the seal that fits on the bottom of the front windshield frome lip near the dash? The OEM seal had the metal inside to grip the lip. Could you send me a total and I'll Paypal. Thanks |
Lo-Fi Version | Time is now: 27th April 2024 - 10:38 PM |
