Oil Galley Plug Kit for DIY'ers, I figured no one else should endure the pain I went through... |
ptravnic |
Aug 10 2007, 07:17 PM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
I've got all the needed drill bits & 1/2" drill. All you'd need is the 5 galley plugs (easy to find @ any hardware store).
I've got it in a box, if you are a reputable member of the board I'll send you the kit if'n you swear on your momma's grave that you'll send it back to me or forward it on to the next Consider this my good deed for the -pt |
type47 |
Aug 10 2007, 07:33 PM
how about posting a "how to"?
ptravnic |
Aug 11 2007, 10:54 AM
how about posting a "how to"? Jake's forum has a very useful "how to", I'm not about to try to replicate it. Also, if you aren't sure of where/what's involved then you prob are not a candidate for the kit.. No offense meant just so ya know. I'm not sure if you have to register or not, but if you are rebuilding an engine it's likely that you've already registered w/his site... http://forums.aircooledtechnology.com/show...ght=galley+plug -pt |
ptravnic |
Aug 12 2007, 11:06 AM
bump
eeyore |
Aug 12 2007, 05:37 PM
I bleeve the proper drill diameter for 3/8" NPT is 9/16 (or 37/64). 1/2" drills 'almost' worked with the taps I used.
Joe Ricard |
Aug 12 2007, 05:53 PM
Yea Mark, if you read the 1st post again. he said he got all the drill bits.
AND a 1/2 in drill. them little bitty drills just won't swing a bit bit. |
ptravnic |
Aug 12 2007, 09:18 PM
Yea Mark, if you read the 1st post again. he said he got all the drill bits. AND a 1/2 in drill. them little bitty drills just won't swing a bit bit. Correct - I bought a bottom of the line harbor freight 1/2" drill. I spent the better part of an afternoon running around town finding this bit/that bit, drill, etc... It's all in a box, ready to loan out to someone - I'm starting to lose faith in the board... Maybe just not a lot of engine rebuilds going on right now - maybe a more popular "off season" project. -pt |
Jake Raby |
Aug 13 2007, 06:00 AM
Correct drill size for a 3/* NPT tap is 9/16"..
So.Cal.914 |
Aug 13 2007, 06:51 AM
I welded them closed, no leak. (IMG:style_emoticons/default/smile.gif)
ptravnic |
Aug 13 2007, 06:56 AM
Joe Ricard |
Aug 13 2007, 12:37 PM
It is still alot of work, not the drilling part just the tapping part.
I finished mine up a few months ago. For me this IS the off season. Too freaking hot even to autocross. |
ptravnic |
Aug 28 2007, 07:07 PM
First up - Verne Snyder. The box is en route. Who wants it when Verne is done?
-pt |
vesnyder |
Aug 31 2007, 06:11 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I am almost done just need to find a place to source the plugs - HELP! Been to two local hardware stures and they had the plugs with the square head not the recessed hex/allen head.
Thanks! |
vesnyder |
Sep 21 2007, 10:01 AM
Who's up next? I completed the job with the kit and it was very easy - and came out very professional! The plugs we not real easy to source but found a place on line! Let me know if you want to borrow the kit?
Big thanks to Pete (aka ptravnic) - really appreciate it! |
toon1 |
Sep 21 2007, 11:09 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I've got all the needed drill bits & 1/2" drill. All you'd need is the 5 galley plugs (easy to find @ any hardware store). I've got it in a box, if you are a reputable member of the board I'll send you the kit if'n you swear on your momma's grave that you'll send it back to me or forward it on to the next Consider this my good deed for the -pt I must have missed this thread, I could've used this as I just recently did this. I also ran around town looking for the right tools and had to borrow 1/2" drill motor, it sucked, wasted 2 hrs shagging down tools. Guy's, I he is refering to a 1/2" drill MOTOR(chuck size) not a 1/2" drill bit. |
ptravnic |
Sep 21 2007, 11:39 AM
I must have missed this thread, I could've used this as I just recently did this. I also ran around town looking for the right tools and had to borrow 1/2" drill motor, it sucked, wasted 2 hrs shagging down tools. Guy's, I he is refering to a 1/2" drill MOTOR(chuck size) not a 1/2" drill bit. Correct, 1/2" drill. Glad to hear Verne got use out of the "kit". Sorry to hear about the trouble finding plugs. Who's next? |
ptravnic |
Sep 30 2007, 10:04 PM
ptravnic |
Oct 21 2007, 11:23 PM
ptravnic |
Nov 26 2007, 07:31 PM
dfwteenerpr |
Dec 1 2007, 12:54 PM
Newbie Group: Members Posts: 22 Joined: 22-October 07 From: lewisville, tx Member No.: 8,252 |
i could use it...
Lo-Fi Version | Time is now: 16th May 2024 - 04:19 PM |
