Does going from a four to a six, require converting from 4 lug to 5? |
rjames |
Aug 12 2007, 12:11 AM
I'm made of metal Group: Members Posts: 3,932 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
An engine swap is not happening anytime soon for me, but I plan on doing it one day. Would doing so require ditching the 4 lug set up for 5 lug?
Ideally I'd probalby be looking at installing a 2.7 six, nothing bigger. |
Aug 12 2007, 12:15 AM
short answer: NO
but, if you add a lot of "go", you might want to consider adding some "oh shit, stop" as well ... (IMG:style_emoticons/default/shades.gif) Andy |
markb |
Aug 12 2007, 12:44 AM
short answer: NO but, if you add a lot of "go", you might want to consider adding some "oh shit, stop" as well ... (IMG:style_emoticons/default/shades.gif) Andy (IMG:style_emoticons/default/agree.gif) |
JPB |
Aug 12 2007, 07:35 AM
Might as well go for some flares since them stockish skins don't have much rubber on the road either. (IMG:style_emoticons/default/beer.gif)
So.Cal.914 |
Aug 12 2007, 07:40 AM
short answer: NO but, if you add a lot of "go", you might want to consider adding some "oh shit, stop" as well ... (IMG:style_emoticons/default/shades.gif) Andy (IMG:style_emoticons/default/agree.gif) There isn't much more to say, you can improve the brakes on a 4 lug but the options for brake type and rims / tires is greater with 5 lug. And then theres the COOL factor. |
Joe Ricard |
Aug 12 2007, 09:45 AM
Vented rotors would be a required item if you were to do DE's or other such race track lapping work.
For street you shouldn't be going that fast anyway. And since getting a six would lead to trackingit then putting big rubber o it would also be a requirement so then flares are the required step. either the HPH one's like JP's car or GT flares like mine. Then when you get going really fast splitters and wings and race seats and harnesses and roll bars or cage. and of course REAL shocks and springs |
propricer |
Aug 12 2007, 10:19 AM
Member Group: Members Posts: 365 Joined: 16-April 04 From: Morgan Hill, CA Member No.: 1,938 |
Adding flares with 5-lug will cost even more than the car is probably currently worth ... if done professionally ...
Steel flares ... $ 1,500 Install ( 8 Hrs per corner x $ 100 / Hr ) ... $ 3,200 Wheels ( 7 & 9 x 16 Fuchs + new lugs, center caps, etc. ) ... $ 3,000 Tires ( mounted & balanced, etc. ) ... $ 1,000 Brakes ( Big Red, etc. ) ... $ 1,500 Incidentals ( paint touch up, etc )... $ 500 Adjust each up or down as you see fit ... so how much does that add up to and what's your car worth ??? Oh, and that doesn't include the cost of the 2.7L along with the 'stuff' necessary to glue it all together !!! |
rjames |
Aug 12 2007, 02:59 PM
QUOTE Adjust each up or down as you see fit ... so how much does that add up to and what's your car worth ??? It sounds like it would be cheaper to buy a car that is finished already, but unfortunately I like the idea of converting a car myself. I'll have to see how much money I can squirrel away in the next year or so. Recently I found a '74 911 with a running 2.7 engine for $4k and it got me thinking... QUOTE For street you shouldn't be going that fast anyway. I'm less concerned about fast, and more interested in 'quick'. My car goes fast, it just takes a long time to get there (IMG:style_emoticons/default/smile.gif) Thanks for all the input guys! (IMG:style_emoticons/default/beer.gif) If I were to go go ahead with this at some point I'd be doing all the work myself, including installation of the flares, although I'm not convinced I'd want them anway. I like the look, but for a car that would probably only be driven on the street they don't seem necessary. Time to buy another lottery ticket... |
So.Cal.914 |
Aug 12 2007, 03:11 PM
Recently I found a '74 911 with a running 2.7 engine for $4k and it got me thinking... If you buy it you will get your engine, front suspension, brakes and it will be 5-lug in front. From the rear you will have your rotors, calipers and hubs (I think they'll fit). Sell the rest. |
Aaron Cox |
Aug 12 2007, 03:40 PM
you dont need flares for a six (IMG:style_emoticons/default/rolleyes.gif)
ive picked up a few 911 M front ends for sub 300 bucks. gets you vented rotors and M calipers, A and S front ends are a tad more. for the rear, send eric a good chunk of change AND your trailing arms, and he will redrill and stud your hubs, do bearings and bushings for ya (IMG:style_emoticons/default/smile.gif) AA |
JPB |
Aug 12 2007, 05:23 PM
scotty |
Aug 12 2007, 05:44 PM
The Fun Never Stops Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
you might want to consider adding some "oh shit, stop" as well ... (IMG:style_emoticons/default/shades.gif) Andy I heartily "third" that! It sounds like it would be cheaper to buy a car that is finished already Isn't there some guy here who's willing to sell his for $25K? (IMG:style_emoticons/default/happy11.gif) |
Pat Garvey |
Aug 12 2007, 08:12 PM
you might want to consider adding some "oh shit, stop" as well ... (IMG:style_emoticons/default/shades.gif) Andy I heartily "third" that! It sounds like it would be cheaper to buy a car that is finished already Isn't there some guy here who's willing to sell his for $25K? (IMG:style_emoticons/default/happy11.gif) Yeah, isn't there? Or, did the Evil One have the fear of Gawd put into him. Or, did he just make the right decision to hold? |
jimkelly |
Aug 12 2007, 08:18 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
my understanding is that stock brakes if in tip top condition will stop most any 914 when street driven - not track raced - with that said - 5 lug is nice and I especially like a narrow body 5 lug conversion. Get sway bars if you don't already have them. jim
Lo-Fi Version | Time is now: 15th May 2024 - 12:42 PM |
