Master cylinder, 17mm or 19mm |
whitey |
Aug 13 2007, 03:12 PM
Member Group: Members Posts: 146 Joined: 8-February 07 From: Coto de Caza Member No.: 7,508 |
What is best way to go...keep my 17mm MC and rebuild it or go to the 19mm. If the 17mm is the way to go where do you get the best rebuild kit for the 17mm.
Thanks, Dave |
So.Cal.914 |
Aug 13 2007, 03:47 PM
What is best way to go...keep my 17mm MC and rebuild it or go to the 19mm. If the 17mm is the way to go where do you get the best rebuild kit for the 17mm. Thanks, Dave Hi Dave, first, you are going to get an arguement eather way. I run a 19mm, the pedal is a little stiffer, what I mean is it is a little harder to push to get the same braking as with a 17mm. But I had never submarined a passenger before I put in the 19mm. I think it stops quicker... (IMG:style_emoticons/default/confused24.gif) |
Cap'n Krusty |
Aug 13 2007, 04:19 PM
Repeat after me: "I resolve to NEVER rebuild, or attempt to rebuild, a master cylinder. If I fail in my resolve, and rebuild one, I will NEVER drive behind, or anywhere near, The Cap'n or anyone he cares about."
If you have reason to believe the master cylinder needs to be rebuilt, it should be replaced with a new one, because the part that needs to be repaired can't be without sleeving it. You may now thank me for saving your life, and the lives of others on the road. The Cap'n |
914-8 |
Aug 13 2007, 05:18 PM
Senior Member Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
agree with cap'n about rebuilding. these things last a long, long time and aren't that expensive to replace with new. buy a new one, it'll probably outlast the rest of the car.
with stock brakes, I'd go 17mm. The brakes are unboosted, and need all the help they can get, IMO. With the same amount of leg pressure, the 17mm will give you greater stopping power than the 19. |
URY914 |
Aug 13 2007, 05:22 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,578 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
The job getting your mc in and out is hard enough without the added work of rebuilding the damn thing. Rebuilding it is not worth the time. Buy a new one.
jhadler |
Aug 13 2007, 06:09 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Don't rebuild it. Throw the old one away and get a new one. Your life (and everyone you share the road with) is far too important...
As for 17mm vs. 19mm? That's an argument that could go on and on and on and on and... A 19mm will give you the same stopping power with less pedal travel. But there's a trade off, the same braking force will require more pedal pressure with a 19mm than it will with a 17mm. The 19mm makes it easier (most would say) to heel toe. But the 17mm, with longer travel, makes it easier (arguably) to modulate the brake pressure at threshold. Which one you will want is ultimately up to you. That being said, I run the 19mm, and I like it. YMMV. -Josh2 |
914-8 |
Aug 13 2007, 06:25 PM
Good summary. Although I think the 17mm makes it easier to heel/toe, because, among other things, it gets better stopping with the same pressure, and puts the brake pedal in a better position (closer) to the accelerator pedal.
But it's all pretty close. The biggest "pro" for the 19 is that it is cheaper to buy and easier to find (is the 17 even available new anymore?). On a stock system, though, if I could find both at the same price, I'd take the 17. |
Eric_Shea |
Aug 13 2007, 06:32 PM
I think I can solve the rebuilding problem... 17mm rebuild kits aren't available.
Get a new 17mm or a 19mm, which ever you prefer. |
blitZ |
Aug 13 2007, 07:32 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I went with a 19mm as it's cheaper and if I go 5 lug one less thing to do. I really can't tell any difference.
BahnBrenner914 |
Aug 13 2007, 08:49 PM
The girl is gone and all I have now is a beat-up teener Group: Members Posts: 301 Joined: 22-May 04 From: Gig Harbor and University Place, WA :: School in Angola, IN :: girlfriend in Sarasota, FL Member No.: 2,094 Region Association: None |
I went with a 19mm when I had to replace my squishy brake pedal. A little extra braking with the 19 and if you upgrade later, it's already there.
lotus_65 |
Aug 14 2007, 08:16 AM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
... so where's the best place to buy the 19mm?
URY914 |
Aug 14 2007, 01:05 PM
If you are a PCA member, try some of the parts suppliers that have ads in the back. There is one in Miami called Vertex that has a lot of standard replacement parts. Don't worry about it coming out of Miami, it probably will come out of a warehouse about 5 miles from your house.
Also Pelican, AA, or several others will have them. |
Eric_Shea |
Aug 14 2007, 05:11 PM
I seem to remember seeing them for $179.00 somewhere... (IMG:style_emoticons/default/confused24.gif)
(IMG:style_emoticons/default/biggrin.gif) |
So.Cal.914 |
Aug 14 2007, 05:15 PM
Eric, I like the black cat at night avatar. Or is that a coal mine in a black out...POV of an oil drill bit?
914nerd |
Aug 14 2007, 05:18 PM
Who you callin' a "Member"? Group: Members Posts: 416 Joined: 18-July 06 From: Los Alamos, NM Member No.: 6,461 |
Best I've seen recently was 185 at AA
lotus_65 |
Aug 14 2007, 07:31 PM
I seem to remember seeing them for $179.00 somewhere... (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/laugh.gif) |
Cap'n Krusty |
Aug 14 2007, 07:41 PM
I went with a 19mm when I had to replace my squishy brake pedal. A little extra braking with the 19 and if you upgrade later, it's already there. Define "a little extra braking with the 19". It takes MORE pedal effort to achieve the same amount of pad movement (pressure) with the 19mm master cylinder vs. the 17mm version. Simple fluid mechanics. The Cap'n |
Eric_Shea |
Aug 14 2007, 07:43 PM
QUOTE Eric, I like the black cat at night avatar. Or is that a coal mine in a black out...POV of an oil drill bit? Think about it... Back to the M/C's; I'm almost certain I saw them SOMEwhere for $179.00 and actual shipping costs! (IMG:style_emoticons/default/biggrin.gif) |
URY914 |
Aug 14 2007, 08:16 PM
I remember when they were $99.00 than they went up to $109.00. (IMG:style_emoticons/default/mad.gif)
Eric_Shea |
Aug 14 2007, 10:30 PM
Yeah but you're really, really old... (IMG:style_emoticons/default/slits.gif)
Lo-Fi Version | Time is now: 15th May 2024 - 01:47 PM |
