What M size fits this captive nut ?, See Pic |
jim_hoyland |
Aug 13 2007, 10:16 PM
Get that VIN ? Group: Members Posts: 9,292 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I believe it's M6, but need the rest of the bolt designation...They are on the inside of the door panels and hold the passenger side arm rest and top pf the drivers side map pocket.
Jim Attached image(s) |
Aug 14 2007, 01:50 AM
Hmmm... Mr. PET is telling me that they're M5x18, but that doesn't sound right. I'm thinking M6x20mm or M6x25mm, with the standard thread pitch. What is that, 1.0 I think?
Hopefully I can order more of those stupid nuts, now that I've found them with the help of Mr. PET. I had tried looking through my hard-copy book long ago and couldn't come up with the correct part number--looks like I finally found it! (IMG:style_emoticons/default/smile.gif) --DD |
ruddyboys |
Aug 14 2007, 08:50 AM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
Can't yopu take it to a local hardware store and try a few screws? I know my local ACE Hardware and Sears Hardware carry a good selection of metric screws and nuts.
jim_hoyland |
Aug 14 2007, 07:29 PM
Thanks Dave.
The captive nut I took to the hardware store was pretty worn. I used to to get a screw, but when I got home to test it out on the door panel--which has near new captive nuts-it wouldn't work. I guess I could have taken the door panel into the hardware stoe |
Cap'n Krusty |
Aug 14 2007, 07:46 PM
Most of the DPOs I've followed think it's "wood screw size". Seriously, it's likely to be a 6mm allen head screw, and about 17-19mm in length, but there are also SOME applications in the doors that use 5mm allen screws. 6mm takes a 5mm allen wrench, 5mm takes a 4. The Cap'n
Lo-Fi Version | Time is now: 15th May 2024 - 01:16 PM |
