LPR AX #4 Sat 8-18 Marina |
Borderline |
Aug 13 2007, 11:44 PM
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
DanT |
Aug 14 2007, 12:00 AM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
you should plan on running the Victorocks for the entire day (IMG:style_emoticons/default/smile.gif) I think part of your problem with the Falkens is that your suspension is just too stiff in the rear to work with street tires. Or you are going to have to change your front rear balance and get the front stiffer or the rear softer. (IMG:style_emoticons/default/blink.gif) How did you like the balance of the car after making the changes I suggested at the last Marina event? (IMG:style_emoticons/default/sawzall-smiley.gif) |
Borderline |
Aug 14 2007, 12:14 AM
The car felt great with the Victorocks! It was soooo sticky that I couldn't really say if it was understeering or oversteering. The car just went where I pointed it. It was great! You're probably right, I should run the whole day on the Vrocks. I just want the rubber to last for the rest of the season (~4 more events). I don't know why I'm so slow on the Azenis. You think the suspension is too stiff for street tires? All I know is that they don't seem to grip well. I'm going to try a little lower air pressure and see if it helps any.
Are you coming down, Dan? |
DanT |
Aug 14 2007, 12:41 AM
Dave_Darling |
Aug 14 2007, 01:33 AM
One word of warning: It's gonna be crowded around there. That's the Monterey Weekend--the Historics, the Concorso, the auctions, alla that is going on. So don't be surprised if there's a lot of (really neat looking!) traffic to and from the event. And you won't be able to find any hotel rooms anywhere near Marina.
--DD |
Lo-Fi Version | Time is now: 18th May 2024 - 10:01 AM |
