Fuel Injector Issues..., ...your opinions please? |
kfieler |
Aug 15 2007, 12:43 PM
kfieler Group: Members Posts: 71 Joined: 26-July 07 From: Southern California (Mojave Desert) Member No.: 7,949 |
After resolving fuel delivery / pump issues on a 1973 914 1.7 that has not been started for over ten years... As soon as the EFI system built-up pressure, two of the fuel injectors started shooting fuel all over the engine bay. My assumption is that the injectors are leaking from the hoses between the fuel rail and injector body (the hoses look cracked and in pretty poor shape). I do not know if the injectors themselves are good, but it seems like a shame to throw them in the trash just because the built-in fuel hoses are bad! Since I don't yet know the condition of the engine, I am looking for a cost-effective method for getting it started for the first time. Questions: 1. Can I salvage these injectors myself? Can an OEM hose be somehow cut-off of an injector and a new hose attached with a clamp? 2. A local auto parts store sells GP-Sorensen fuel injectors for $69.00 each; however, I've read some negative reviews of this brand. Anyone have any experience with GP-Sorensen brand injectors in a 914? 3. I realize that remanufactured Bosch injectors are available. Does anyone have any experience with using rebuilt injectors? And, lastly, if this were your car, what would you do? Any advise you can share with a "newbie" is greatly appreciated! Thanks! - Keith |
Cano |
Aug 15 2007, 12:50 PM
Member Group: Members Posts: 110 Joined: 29-September 04 From: Goshen, KY Member No.: 2,854 Region Association: None |
When my injectors were rebuilt, the old lines were removed and new ones clamped on. I think you can just grind the metal clamp down that holds the short hoses on, pull them off, and replace with a correct clamp.
markb |
Aug 15 2007, 01:25 PM
Yup, cut off the old hoses, clamp on the *proper* hose, with a *proper* hose clamp. And while you're in there, replace ALL of the other fuel lines.
And then move on to the rubber brake lines. |
jasons |
Aug 15 2007, 01:36 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
Yup, cut off the old hoses, clamp on the *proper* hose, with a *proper* hose clamp. And while you're in there, replace ALL of the other fuel lines. And then move on to the rubber brake lines. (IMG:style_emoticons/default/agree.gif) Make sure you use fuel line rated for FI (not cheap) and hose clamps with rounded edges. All available from PelicanParts. You should probably replace all your rubber FI lines, or carry a fire extiguisher. Also, you can get your injectors tested and cleaned with new seals, filter screens, and pintle caps by witchhunter performance $60 for all 4, and they are super fast. http://www.witchhunter.com/ |
zymurgist |
Aug 15 2007, 01:45 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Make sure you use fuel line rated for FI (not cheap) and hose clamps with rounded edges. (IMG:style_emoticons/default/agree.gif) Please try to get 7mm metric hose. 5/16" fuel injection hose (what you'll probably find at the FLAPS) is closer in diameter to 8mm and if used will leak sooner or later. You also want to get FI clamps... they don't look like the worm type clamps in your picture above. BTDT. The guy who built Babydoll's engine used 5/16" hose and worm clamps and the engine bay always smelled of gasoline. We don't need any 914's turned into car-b-ques, they're rare enough already! |
914werke |
Aug 15 2007, 01:56 PM
"I got blisters on me fingers" Group: Members Posts: 10,059 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
BTW the proper injectors for a 1.7 are Yellow in color not Green (2.0 application).
as advised above start by replacing all the old lines then youll be able to tell if its the injectors themselves that are leaking (and it is possible). |
greybeard50 |
Aug 15 2007, 02:02 PM
Newbie Group: Members Posts: 46 Joined: 24-September 06 Member No.: 6,909 |
Great advice & info here...
Am I the only one in the world who did not know that "FLAPS" meant "Friendly Local Auto Products Store" ??? I feel so....you know....stupid. |
xperu |
Aug 15 2007, 02:03 PM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
Yes, I agree, the injectors should be yellow. |
kfieler |
Aug 15 2007, 02:45 PM
Yup, cut off the old hoses, clamp on the *proper* hose, with a *proper* hose clamp. And while you're in there, replace ALL of the other fuel lines. And then move on to the rubber brake lines. (IMG:style_emoticons/default/agree.gif) Make sure you use fuel line rated for FI (not cheap) and hose clamps with rounded edges. All available from PelicanParts. You should probably replace all your rubber FI lines, or carry a fire extiguisher. Also, you can get your injectors tested and cleaned with new seals, filter screens, and pintle caps by witchhunter performance $60 for all 4, and they are super fast. http://www.witchhunter.com/ Jasons: Thanks for the tip about Witchhunter. That really looks like a cost-effective approach to solving my problem! |
kfieler |
Aug 15 2007, 02:48 PM
BTW the proper injectors for a 1.7 are Yellow in color not Green (2.0 application). as advised above start by replacing all the old lines then youll be able to tell if its the injectors themselves that are leaking (and it is possible). Yes... I noticed that too (Green injectors rather than Yellow, for a 1.7). Alas, green injectors are what came with the car - so that is what I'm stuck with for now. I am making an assumption that the Green injectors WILL work in a 1.7 - possibly just cutting-down on fuel economy? Thanks! - Keith |
markb |
Aug 15 2007, 03:16 PM
PM me your address, I've got a bag of tested 1.7 injectors. I'll send you a set.
jasons |
Aug 15 2007, 03:22 PM
Yes... I noticed that too (Green injectors rather than Yellow, for a 1.7). Alas, green injectors are what came with the car - so that is what I'm stuck with for now. I am making an assumption that the Green injectors WILL work in a 1.7 - possibly just cutting-down on fuel economy? Thanks! - Keith Hey maybe I can buy you 20hp. Are you sure your car doesn't have a 2.0 in it somehow? Check the case numbers and/or do the heads have 3 or 4 studs where the intake runners mount? |
kfieler |
Aug 15 2007, 03:45 PM
Yes... I noticed that too (Green injectors rather than Yellow, for a 1.7). Alas, green injectors are what came with the car - so that is what I'm stuck with for now. I am making an assumption that the Green injectors WILL work in a 1.7 - possibly just cutting-down on fuel economy? Thanks! - Keith Hey maybe I can buy you 20hp. Are you sure your car doesn't have a 2.0 in it somehow? Check the case numbers and/or do the heads have 3 or 4 studs where the intake runners mount? I checked the case number and, unless I am mis-informed, the engine checked-out to be a California 1.7. I am showing ignorance here, but is this what you mean by the intake runners? As pictured, there are 4 studs. Thanks for the help! - Keith |
jasons |
Aug 15 2007, 03:48 PM
I checked the case number and, unless I am mis-informed, the engine checked-out to be a California 1.7. I am showing ignorance here, but is this what you mean by the intake runners? As pictured, there are 4 studs. Thanks for the help! - Keith Yeah, those 4. If you had 3, that *could* be an indication of a 2.0. I thought there just might be a chance you got the rest of the 2.0 with the injectors. |
kfieler |
Aug 15 2007, 04:08 PM
I checked the case number and, unless I am mis-informed, the engine checked-out to be a California 1.7. I am showing ignorance here, but is this what you mean by the intake runners? As pictured, there are 4 studs. Thanks for the help! - Keith Yeah, those 4. If you had 3, that *could* be an indication of a 2.0. I thought there just might be a chance you got the rest of the 2.0 with the injectors. Ha... for some reason I never seem to be lucky like that. (IMG:style_emoticons/default/wacko.gif) Unless someone has been inside the engine, I believe I probably have the original engine that came with the car - along with a set of rebuilt, stock 1.7 heads. Oh well, it's a start! Thanks! |
swl |
Aug 15 2007, 04:54 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Carrying on with the 'bonus' engine thought: If someone put in big cylinders and pistons maybe they would put in the 2 litre injectors?
It would also be interesting to see if the ECU part number married up with the engine type. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:46 PM |
