Engine Parts Detailing (paint? no paint?), Your opinions, PLEASE... |
kfieler |
Aug 17 2007, 01:29 PM
kfieler Group: Members Posts: 71 Joined: 26-July 07 From: Southern California (Mojave Desert) Member No.: 7,949 |
Okay... my fuel injectors are out of the car and are being shipped-off for servicing by WitchHunter. I can't bring myself to put dirty parts back in a car, so in the down-time, I want to clean and prep them for re-installation. Here's where I need help... 1. What is your favorite method for cleaning 914 parts (such as fuel rails, injector retainers, etc.)? 2. After cleaning them, do I leave them the h*ll alone and stick them back in the car, or should they be shot with some sort of clear-coat? I am a details-oriented person and would love to "dress-up" the engine as I go. I have contemplated painting parts (or having them powder-coated) - like intake tubes - as I R&R them, but I don't know if that is a big mistake or not. I am not going for a concourse restoration with this car, so I don't mind making a few cosmetic changes. I don't, however, want to wind-up with a car that looks like a circus clown and become the subject of someone else's future PO story! Any advise you "pros" can provide to a "newbie" would really be appreciated! Thanks! - Keith |
John |
Aug 17 2007, 02:45 PM
Those were plated. They were yellow. You could have them re-plated CAD or yellow zinc, or you could always paint them.
In my opinion, if I were painting them, I would use a subdue color. Either black or gray to match the intake runners. In the end, it's up to you. |
Brian Mifsud |
Aug 17 2007, 02:48 PM
Mechanical Engineer Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
A few guys on the forum have bought the home-plating kits and seem to like the results. You can put a heavier than original Zinc plating on those parts and never have to worry about them again.
rhodyguy |
Aug 17 2007, 02:50 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,081 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
wipe/scrape off the heavy grime, wipe down with laquer thinner, run them through the dishwasher, don't get caught, put them on.
k |
jaminM3 |
Aug 17 2007, 03:47 PM
Member Group: Members Posts: 418 Joined: 23-March 07 From: SLC, UT Member No.: 7,619 Region Association: Intermountain Region |
Has anyone tried the home powdercoating kit from Eastwood? I am curious how well it works.
Cap'n Krusty |
Aug 17 2007, 03:52 PM
Those were plated. They were yellow. You could have them re-plated CAD or yellow zinc, or you could always paint them. In my opinion, if I were painting them, I would use a subdue color. Either black or gray to match the intake runners. In the end, it's up to you. Yes, they were plated. No, they weren't "yellow". They were a dull silver version of what's called "bright cad". The Cap'n |
jasons |
Aug 17 2007, 04:01 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
When I went through this.....
I just lightly cleaned my rails (steel wool or scotch brite) and sent everything else out for powder-coat, semi gloss black of course. But, I sent a pile of parts (all my tin and + more) to the powder-coater at one time. If I were doing a home job, I would probably just rattle can those parts semi black. |
Pat Garvey |
Aug 17 2007, 06:34 PM
Krusty is correct - the retainers were NOT cad plated, but bright silver plated. The fuel rail, however, WERE cad plated. I'll send a pic if anyone's interested.
Don't powder coat parts that weren't painted, please! It's easy to clean up the retainers. Degrease, bufff & apply Simichrome. They'll look new. Pat |
jasons |
Aug 17 2007, 07:18 PM
DanT |
Aug 17 2007, 07:38 PM
wire brushed mine to get off the gunk and then hit them with some rustoleum black.
also wire brushed and then hit the fuel rails with some metal polish. Attached image(s) |
Lo-Fi Version | Time is now: 21st May 2024 - 11:05 PM |
