Tranny removal?, Which way is best? |
por73914 |
Aug 22 2007, 08:49 AM
I don't know what the hell I am doing... Group: Members Posts: 349 Joined: 10-April 07 From: Fayetteville, AR Member No.: 7,660 |
OK My 74 2.0 (ole Rusty) died a few weeks ago and I bought a parts car for the engine. Did the swap and the new (to me) 2.0 runs great! However the clutch/tranny does not work so great. So this weekend I am going to swap trannys and clutch with the one I took out of ole Rusty. Now I have done lots of 911 clutches and have always dropped the engine and tranny together, but I was looking on Pelican for a tech article on changing the clutch out and it say to just drop the tranny. So which way would you go? Drop it all or just the tranny? (IMG:style_emoticons/default/beerchug.gif)
Joe Ricard |
Aug 22 2007, 09:29 AM
Doesn't really matter.
I would do just transaxle because that's my mood today. Just put a jack stand under the engine to support. |
Krieger |
Aug 22 2007, 09:33 AM
Advanced Member Group: Members Posts: 4,706 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
It's easy to do the tranny, and not too bad if you have to remove the flywheel.
So.Cal.914 |
Aug 22 2007, 09:34 AM
For just changing the tranny/clutch I would not drop the engine too. Lower the tail
down so you have enough room to pull the tranny and support the engine in that position and pull the trans. |
por73914 |
Aug 22 2007, 09:35 AM
Thanks Guy! (IMG:style_emoticons/default/drunk.gif)
Lo-Fi Version | Time is now: 10th May 2024 - 10:42 AM |
