| cobra94563 |
Aug 22 2007, 12:12 PM
Chris ![]() ![]() Group: Members Posts: 341 Joined: 1-March 05 From: San Francisco Member No.: 3,696 |
Is that usually the relay is bad or a short in the wiring?
(Trying not to buy the relay and then find out it's the wiring.. (IMG:style_emoticons/default/blink.gif) ) Also, has anyone identified an non-oem (cheaper) replacement. Actually, I think the one in there is a non-oem substitute, but it has 4 similar prongs and it somehow fit. The left blinker flashes ok, the right and the hazards just buzz. (IMG:style_emoticons/default/type.gif) Thanks. |
| 904svo |
Aug 22 2007, 01:40 PM
904SVO ![]() ![]() ![]() Group: Members Posts: 1,129 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Is that usually the relay is bad or a short in the wiring? (Trying not to buy the relay and then find out it's the wiring.. (IMG:style_emoticons/default/blink.gif) ) Also, has anyone identified an non-oem (cheaper) replacement. Actually, I think the one in there is a non-oem substitute, but it has 4 similar prongs and it somehow fit. The left blinker flashes ok, the right and the hazards just buzz. (IMG:style_emoticons/default/type.gif) Thanks. I bought a Tridon/Stant EP26 12Volt 4Terminal Flasher at my auto parts store which work fine. |
| Brando |
Aug 22 2007, 02:57 PM
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
I've run the cheap units - results in not working right or dying out.
Go with the oem hella. |
| dr914@autoatlanta.com |
Aug 22 2007, 03:26 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,254 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
please start by confirming that the bulbs and connections in the four corner turn signal bulbs are good and that you do not have a ground plugged in where a hot should be. You can find the concise wiring plug in sequence in the book "TECH TIPS 700" After verifying several times, disconnect the master cylinder switch and confirm that there is no back feed from a leaking ground through the switch. THEN disconnect the turn signal switch and try the emergency flashers and see if things work correctly. If so the turn signal switch is bad. If not replace the flasher. You will need the proper four pin type as this flasher works the em brake warning the low brake warning the turn signal and the em flasher
| cobra94563 |
Aug 22 2007, 04:40 PM
Thanks ALL. That is good info to help me track down the source of the problem!!
Lo-Fi Version | Time is now: 16th November 2026 - 06:45 AM |
